Mowing Discharge chute mods?
/ Discharge chute mods? #1
Tdog
SE Louisiana
BX22
Has anyone devised a way to raise the discharge chute on your MMM to help you squeeze into tighter places? I can't see using a chain or rope as there'd be too much chance of it being dropped & eaten by the blades.
I've got a couple of spots that are accessible except for the discharge plate. I won't remove it entirely since I use the BX up near the house.
Thanks,
Jack
/ Discharge chute mods? #2
I use a short blue bungee. I leave both end clipped to the seat frame and when needed, I can lean over pick up the end of the deflector and clip it up. You are wise not to remove it as a projectile can fly longer than you'd expect. Be safe.
/ Discharge chute mods? #3
I have had a piece of light rope on mine for a dozen years now, no problem. I normally keep mine up 15-20 degrees so that it doesn't clog and I can pull it all the way up when I need too. The other end of the rope is tied to the throttle on the dash (B2710).
/ Discharge chute mods? #4
Ditto on the bungee cord. My Kubota TG1860 deck has a steel chute, I drilled a quarter-inch hole near the edge to hook the bungee, the other end is hooked under the seat. Easy to hoist the chute up when needed, and there is always some tension on the bungee so it isn't flopping around and won't come loose.
Pete
/ Discharge chute mods? #5
X3 for bungee. Allows me thru narrower gate, and when stored in barn...
/ Discharge chute mods? #6
x4 for bungee. Makes a big difference when mowing heavy grass.
/ Discharge chute mods? #7
Pete
This is exactly what I did on my B2929. Drilled small hole and bungeed it up.
/ Discharge chute mods? #9
I raised mine up to a shelf in the garage, to be reinstalled when I sell.
Take Care,
Doug in SW IA
Thanx all. I'll be drilling tomorrow. I'll just need to make sure the chute is down when I'm around the house & plate glass windows. I hadn't thought about it making a difference in tall grass, but it makes sense that it would cut better w/o the chute to restrict the cuttings being discharged.
Jack
/ Discharge chute mods? #11
Gentlemen: Just remember that when you lift that chute with the PTO engaged...there is no downward deflection for any kind of projectile that possibly could have been sucked up and hit by blade force strong enough to propel that object a long distance and cause damage or bodily harm. Doug in an earlier post stated he has removed his chute up to a shelf? The assumption then is that he has chosen to mow without the safety guard in place. Risky business.
/ Discharge chute mods? #13
My Dad used a bungee cord on our 1505 MMM, worked great!!
/ Discharge chute mods? #14
Take Care,
Doug in SW IA
I can hear the sirens now! The Safety Police are on their way to get you! LOL! I'm not even going to say what I did with mine!
/ Discharge chute mods? #17
Next time buy a rear discharge deck.:D
ROADTEC RX700 MILLING MACHINE (A64279)
ROADTEC RX700...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2016 Nissan Sentra Sedan (A61574)
2016 Nissan Sentra...
2024 GMC Yukon Denali 4x4 SUV (A61574)
2024 GMC Yukon...
49" X 74" TAILGATE (A64280)
49" X 74" TAILGATE...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
