Buying Advice buying first time
/ buying first time #1
cfield
brookneal,va
1953 Ford Jubilee
i have never owned a tractor before, and am looking at a 1953 ford golden jubilee. it appears to be taken well care of, just a little faded paint. the description describes a machine with 100% compression in all cylinders, new guages, new brakes, new akle seals, new points, and new lower arm links. the front tires are weighted. the rear tires are filled and have chains on them. this tractor, with a 5ft bushhog, rear scoop, 6ft blade, and boom pole with a 2 hour delivery for 3600. is this a good deal? i have not been able to drive it or see it in person yet. are there other questions i need to ask prior to buying? i have found beat up looking similar models for 2000 and totally restored for 4500, so i think maybe a good fair price for seller and buyer?
thanks
/ buying first time #2
well i can tell you this an a few other things.you need to go look at it an drive it.make sure it shifts to all gears.make sure the clutch an brakes work.also lift the 3pt with shredder on it to see how it raises an lowers.
/ buying first time #3
As long as you are not asking for this tractor to do the work of a modern tractor, then it sounds good so far. It is 60 years old and will build muscles in your arms and shoulders just steering it. Two things come to immediate mind, oil pressure and worn rear tires to look for. He says new gauges, so it should show 20-40 PSi operating. New rear tires if needed will cost $300-500 each.
I say go and look at it, it sounds reasonable if it is as he states.
/ buying first time #4
Go with something in the 60s for a live PTO. Post this in the Ford Forum so Sound Guy can chip in. He knows Fords.
/ buying first time
is there a way to copy post to another forum.
/ buying first time
what is the shredder you refer to to lift the 3pt with? i am new to looking a tractors, so i dont know all the terminology
/ buying first time #7
What you call a bush hog is actually a shredder. Bush Hog is a name brand.
/ buying first time #8
I am kind of in the same boat as you. I've never owned a tractor, and seem to be looking at older stuff. After a lot of reading here, I am going to get something newer with live PTO as has been stated. The older ones are cool, but they are outdated.
/ buying first time #9
The jubilee is pretty much an 8n with a few improvement as in a few more HP and some models did come with a live PTO. They may be 60 years old but they are solid tractors.
Just out of curiosity what task are you planning to do with your future tractor? It's hard to give advice if we don't know what you plan to do with it. If your looking at food plotting or hobby farming on a small scale its a great tractor.
As for the price, It seems like a fair deal if everything checks out on the tractor.
/ buying first time #10
We have an NAA as well as some later Ford 600's, good tractors, but I would not recommend one to someone new to tractors. We bought a well used Case 995 made somewhere in the 60's and it was reasonably priced, has independent PTO and power steering in addition to a ROPS, much better for someone new to tractors and willing to maintain one. There are a LOT of older good models from all makes out there, but be sure to have them checked out by someone knowledgeable on them, I use my brother.
Good luck.
/ buying first time
i am just starting a small farm- mostly vegetables- peppers, tomatoes, etc.... so i think i will need bushhog, plow, scoop, and to be able to pull a trailer.
/ buying first time
the oil pressure is 45 with cranking cold, and maintains 25 at idle, which seems to be pretty good for a 60 yr old tractor.
/ buying first time #13
How much property do you have? How much ground are you planning on planting?
/ buying first time #14
No live PTO on that machine
/ buying first time #15
I bought a ~ '48 9N when we moved to the country 15 years ago. I spent more time wrenching than in the tractor seat. It looked great on day of purchase. On my experience, I would suggest saving some more and buying a diesel utility tractor that meets your needs. My 2 cents. SB
/ buying first time #16
thanks
If you have $3600 to spend, I'd get out of the 1950s and into the 1960s. My 1964 MF135 diesel cost $3600 when I bought it in July 2006. It's a lot more tractor for the money than that old Ford you're eyeballing. There are gas engine models of the MF135 if you don't want to mess with a diesel.
Good luck.
John Deere Z960M Zero Turn Mower (A64047)
John Deere Z960M...
1974 Ohio Body Dry Van Trailer (A64047)
1974 Ohio Body Dry...
2006 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2006 Montone...
2022 Case 5550 Trident Spreader LOW HOUR (A63118)
2022 Case 5550...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
