4X4 downhill traction issue
/ 4X4 downhill traction issue
Made some progress this week on the brake project.Dropped the tractor off at the local ATV dealer so they could help me figure out the best type fittings and order correct length brake lines.A buddy at work worked on truing up the discs on the brake lathe as they wobbled a bit(took the discs off and trued the spacer rings) and were slightly out of orbit on the roll.I made the caliper brackets from some 4" by 1/4" thick angle iron I already had.Only took me 10hrs to make them and get them painted :) The first pic is shot from the rear of the left front wheel.
/ 4X4 downhill traction issue #122
Now that's what I'm talking about. I'm curious to see how you rig up the master cylinder and if you use the same brake pedal. This thing may stand on it's nose.
/ 4X4 downhill traction issue #123
Neat project and looks good. I don't know what the connectivity is between the front and rear wheels on your machine. If it is solid (as opposed to some sort of fluid) then the brakes you apply on the front wheels will also brake the rear wheels while you are in 4wd through the drivetrain. That works in spades on large farm tractors. At some point I begin to wonder if you are investing too much in a small machine , but then we all have our hobbies and ... hey looks like a workin' machine !
/ 4X4 downhill traction issue #124
As usual Locknut.....impressive work....
The cylinder has two line outputs,one for each caliper.It will be actuated with a hand lever,yet to be fabricated.Not knowing how much torsional twisting force the axle housing will take,I will not be trying to stand this thing on its nose.
Yea,that's the problem,there is no mechanical link between the two axles as the front is hydraulically driven and has very little holding resistance.And yes,it's a fairly expensive project but the consequences of a runaway tractor downhill can be much more costly.
/ 4X4 downhill traction issue #128
Outstanding work. I love to see guys overcoming problems with their own ingenuity.
Nice progress.
Your brake caliper is on the wrong side.
You mean the bleeder screw on the bottom? I can still bleed em out and after the air is out it won't make any difference.Or,I'll check tonite to see if they will swap sides.
/ 4X4 downhill traction issue #131
Maybe he meant front versus back ?? I'm not sure why it would matter.
/ 4X4 downhill traction issue #132
You will not get all the air out with the bleeder on the bottom.
Ok Roger,I swapped sides and the bleeders are on top.The saga of the the sliding tractor is now fixed.The brake system is very smooth and controlled.The last pass I made in the video below is 35 deg and can go fast or slow and stop at will.There's also a pic of a steering stabilizer I added to fix a horrible death wobble inherent to this model.
Click;
/ 4X4 downhill traction issue #134
It looks safer to operate now. 35* is pretty steep.
/ 4X4 downhill traction issue #135
Looks good, hope this will resolve your problems. Very nice work and resourcefullness.:thumbsup:
/ 4X4 downhill traction issue #136
Probably means 35%. A 35 degree slope is over 70% and you are not going up or down a 70% slope on any wheeled vehicle.
/ 4X4 downhill traction issue #137
Click on the picture of him on the mower. It is 35*.
/ 4X4 downhill traction issue #138
/ 4X4 downhill traction issue #139
Yep, that's the right chart. If you double click on it, it will come up in a size you can see/read the numbers. The 35 or 40% slopes are quite tractable for wheel vehicles. The 35 degree (over 70%) slopes are not feasible.
Hey JWR,come on over.Another 30ft back it goes up to 40 deg and a lot farther to the bottom.We'll have some real fun then..:eek:
Prime 283 (A64126)
Prime 283 (A64126)
(2) Tractor Wheel Weights (A65640)
(2) Tractor Wheel...
2 Rolls of Screen (A62613)
2 Rolls of Screen...
2006 Utility Spread Axle Trailer (A62679)
2006 Utility...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
International 574 Loader Tractor (A66285)
International 574...
