Older Hay Wagon
/ Older Hay Wagon #1
apilot
Brooklyn Mi
John Deere 3520
I have recently purchased an older hay wagon and am trying to find information on the make. It has steel spoked rims and is in pretty good shape except for the bearings. If anyone has information about this wagon I would greatly appreciate it. Hopefully it will help in identifying the bearings. I am unable to find a name or insignia but a few areas have part or serial #s.
Thanks
/ Older Hay Wagon #2
Take it apart. If it has roller, ball or timken bearings they should be generic or a place dealing in bearings may be able to find a replacement.:)
It may also just have sleeve bearings. Those may be harder to replace.:confused:
/ Older Hay Wagon
I am in the process of cleaning the old grease off the hubs and removing them to get to the bearings. The paint scheme under the grease is red. IH or Farmall?
Thanks
/ Older Hay Wagon
I have found the IH insignia on the dust caps. Is there a secret on removing them? I do not think they are threaded even though there is a place for a socket or wrench on them.
Thanks
/ Older Hay Wagon
I have the wheel off and there is slop in the castle nut. There is no way to tighten because the spindle is not threaded. There should be some sort of rear seal to keep the grease in the assembly, but there is not.
Any help will be appreciated.
Jeff
/ Older Hay Wagon
Well I have put the wheel assembly back together. Quite a chore. Not as simple as a trailer bearing. The castle is eccentric. Many spacers and dogs. Lots of crusted grease. I will be taking the assembly back apart soon as all four wheels are loose. I will post pics then.
Thanks for you response and I hope to be back into it sometime next week.
Jeff
:thumbsup::thumbsup:
/ Older Hay Wagon #8
I have the same wheels. I need a hub cap to complete the set. Would you sell me a cap? My wheels are a little loose, so I will be correcting that after I clean up the wheels!
/ Older Hay Wagon
I would, but I need the caps.
Jeff
/ Older Hay Wagon
That will have to work. I appreciate the reply.
Jeff
2009 Peterbilt 367 Flat Bed (A64047)
2009 Peterbilt 367...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2013 Moritz Trailer (A63116)
2013 Moritz...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
