Lk3054 Glass bubbles leaking ...
/ Lk3054 Glass bubbles leaking ... #1
JDKiotiboys3
Member
Mooresville In.
Kioti LK3054,John Deere 420 L&G
I'm sure I am not the only one. Any one ever changed one out? I'm sure it's just a rubber gasket around the glass right?
Sent from my iPhone using TractorByNet
/ Lk3054 Glass bubbles leaking ... #2
Are you referring to a sight glass in the front axle housing? (I'm not well versed on your model Kioti, but that is the only place one exists on mine....)
Yes on front axle and on the side of the trans. Both leaking
/ Lk3054 Glass bubbles leaking ... #4
I took mine out on the CK20 and cleaned it when I did the 400hr obligatory oil change, it just seals with a o-ring or rubber is all.
How'd you get them out?
/ Lk3054 Glass bubbles leaking ... #6
On mine the sight glass is made to be unscrewed with a 24mm socket or wrench, just unscrewed it.
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A64553)
2006 Snorkel AB50J...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
40ft High Cube Shipping Container (A64553)
40ft High Cube...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
