Lk3054 Glass bubbles leaking ...
/ Lk3054 Glass bubbles leaking ... #1
JDKiotiboys3
Member
Mooresville In.
Kioti LK3054,John Deere 420 L&G
I'm sure I am not the only one. Any one ever changed one out? I'm sure it's just a rubber gasket around the glass right?
Sent from my iPhone using TractorByNet
/ Lk3054 Glass bubbles leaking ... #2
Are you referring to a sight glass in the front axle housing? (I'm not well versed on your model Kioti, but that is the only place one exists on mine....)
Yes on front axle and on the side of the trans. Both leaking
/ Lk3054 Glass bubbles leaking ... #4
I took mine out on the CK20 and cleaned it when I did the 400hr obligatory oil change, it just seals with a o-ring or rubber is all.
How'd you get them out?
/ Lk3054 Glass bubbles leaking ... #6
On mine the sight glass is made to be unscrewed with a 24mm socket or wrench, just unscrewed it.
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
2018 CATERPILLAR 320GC EXCAVATOR (A65053)
2018 CATERPILLAR...
New/Unused Wolverine Mini Quick Attach Pallet Forks (A65583)
New/Unused...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
Toro Workman Utility Cart (A64553)
Toro Workman...
2015 FREIGHLTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2015 FREIGHLTLINER...
