belt to chain
/ belt to chain #1
xtruckerbob
Louisiana
Kubota BX 25D, Kubota Bx 2670, Kubota RTV, 900, Kubota L-2600, Kubota G-3200, Kubota Z121S, John Deere L-160
Does anyone know if there is a conversion to change belt pulley to chain sprocket drive on a 3pt mower?
/ belt to chain #2
Belts are designed to slip a little under too much pressure. If you change to gear and chain, you will more than likely break your chain every time you use it. Especially on starting of the deck, lot's of torque there.
/ belt to chain
Thanks Don87
Now guess I will sit back and do some rethinking.
/ belt to chain #4
I kinda in agreement with don. You need a little slippage. You could easily convert it to a 50 or 60 size chain that wouldnt break but something else more expensive under there probaly would break.
/ belt to chain
My project was a 48" finishing mower that rusted out. I made a new deck 60" but only used the 2rotors from the old deck and replaced the 24" blades with 30". The 9" pulley that drives the deck needs to be changed because my ratio is wrong. (I did not leave room for larger pulley) When ever I try to mow the the belt will slip. Since the chain is not a good idea I will just add another rotor. I think when I go back to the small 20" blades itshould cut fine.
/ belt to chain #6
Could you change to a wider belt size to reduce slippage? Might be easier to change pulleys than adding another blade drive. Are you using an "A" width or "B" belt?
/ belt to chain #7
A bigger belt, or perhaps a pair of belts.
I'm not sure about the acceleration and slippage. Certainly there are many gear driven PTO products.
Perhaps you could use a spring loaded tensioner pulley on the pulling part of the chain. Give it a stiff spring, and expect the spring to take up some of the torque.
/ belt to chain #9
There would have to be a good way to reduce the shock to the system.
Many transmission clutches have springs to reduce the shock to the system. It should be easy enough to apply the same principle to the PTO shaft. There are, of course, also PTO shafts with built in torque limiting clutches.
/ belt to chain #10
Chain drives typically operate at lower speed/higher torque than belt drives do.
They also require lubrication to avoid rapid wear & failure. Stick with the belts.
I'd go with either pjbci's idea to use a wider belt, or Cliff's double sheave idea, if there's enough space.
HONDA generator (A64553)
HONDA generator...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2007 Dodge Ram...
2011 Ford E-250 Cargo Van (A64556)
2011 Ford E-250...
2003 Freightliner FS65 Thomas School Bus (A64194)
2003 Freightliner...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
