ATV or UTV
/ ATV or UTV #1
Fidler4
East Tennessee
None yet
I keep going back and forth on whether to buy an ATV or UTV so I thought I would get some input. DW and I have 10 acres (5 wooded, 4 pasture, 1 house/lawn). This is a 2nd home for us which we only get to spend 3-4 weeks per year at. Next year I retire so I will be ale to spend more time there but wife is not retired and kids are in HS so for the next 4-5 years our time there will be limited. After that we will spend at least 6 months there each yr. I plan on buying a tractor in about 4-5 yrs when I will be there more. In the meantime I wold like to get a UTV or ATV to help do general maintenance around the property. For example cutting up fallen trees for firewood, moving firewood around & clearing out junk left in the woods by previous owner. So my primary reason is for the utility use of it but I also have two teenagers that would enjoy using it for recreation on the property.
I have lived in the city all of my life so I have very little experience with rural living. Most of what I have learned has been through this forum. I suppose a 3rd option is to buy tractor now but it won't get much use over the next 4-5 years so I didn't want to spend that much money on something that won't get much use. Our friends live nearby and they have a JD2025 for their 12 acres which I could borrow if needed.
Thanks,
J
/ ATV or UTV #2
The ability to carry things in the bed, whether it be tools or trash, is what makes the utv stand out for work duties around here.
I have both and the atv has seen very little use since buying the utv.
/ ATV or UTV #3
I also have both;use my Rhino every day.I only use the ATV for spring work and hunting.Even the small bed on the Rhino's are better than a trailer or the racks of the ATV.Plenty of sport in the UTV's if that is what you are looking for and they are safer.
/ ATV or UTV #4
The same as DT86 ans nybirdman. I have a Polarius Ranger Crew and use it for everything. up to almost 800 pounds of rock. It takes up to six people or ten dogs, and tools anywhere in any weather. We have 112 acres and all kind of ground as the SOuth is on a river with some swamp.
/ ATV or UTV #5
Pretty much the same as the others, our Rhino gets regular use while the 700 Grizzly only gets used during deer season.
/ ATV or UTV #6
Both are great vehicles.....just depends on how you intend to use them. The guys are right on with the UTV comments.....but....most of them have more property than you have. I have an ATV and only about 6ac. I have a utility trailer I haul around the property....this set up works well for me. I use the atv for hunting and pleasure riding as well. Either way.....you'll enjoy whatever you buy.:thumbsup:
/ ATV or UTV #8
Kids and tractors do not mix.
Go with a UTV with Turf Tires for max stability. Responsible kids can drive a UTV safely and begin learning about driving the car........
If this purchase will substitute for a tractor, get a UTV with a Hydrostatic/tractor (HST) transmission rather than belt drive. The implement in Photo #4 is an ABI "Gravel Rascal". You cannot not work one of these little wonders without HST and 4-WD.
Budget for an all-terrain dump trailer; one that carries the load low, not high. Mine is an older MUTS.
MUTS - Multi-Use Trailer System for your ATV, Quad and 4 Wheeler - Welcome
I have no experience with them but the two all-terrain trailers from Monroe Tufline look interesting:
http://www.monroetufline.com/products/uc20-30-utilitycarts.htm
/ ATV or UTV #9
I am no longer comfortable riding two up on an ATV unless it was designed for it, so my recommendation is if you get only an ATV and plan on carrying someone, get one designed for it. I know a couple of brands offer them. I accept some will disagree and I am not talking slow riding on flat ground.
/ ATV or UTV
Thanks for all of the suggestions you definitely convinced me a UTV is the way to go. I will be at the house for a couple of weeks in August and will look for one. I think there is JD dealer and a motorcycle place nearby that sell UTV's.
Thanks again,
J
/ ATV or UTV #11
Also check Kubota dealers, their RTV is a good workhorse.
We have two ATVs. For rough or hilly terrain, two up riding is not very safe on an ATV. Five or six years ago, we bought the Kubota RTV900 and the 4 wheelers have pretty much sat idle since then. The RTV is good for just about everything: casual recreational riding, work, hauling, 1500# dump bed capacity, etc. It's hydrostatic transmission so you don't have to worry about belts.
The Kubota isn't cheap but you get what you pay for.
/ ATV or UTV #12
Good luck, there are a lot of good models available now. I am not sure what I would buy there are so many good ones.
/ ATV or UTV #13
I would own a utv if I didn't have the need for being able to manuver easily in the woods (ie. where there are no trails established). I wish I was able to afford both an atv and a utv. I make my atv suffice though by adding a rack basket on the rear.
/ ATV or UTV #14
Are you planning on leaving it there when you are not there? A UTV will require a trailer to transport while an ATV fits in a pickup bed. The only trailer I have that my UTV fits on is a 18' equipment trailer. If you leave it there can you secure it inside a building? Leaving them outside shortens their lives and makes tempting targets for thieves. ATVs are easier to fit into storage sheds. Is your land hilly or mostly flat? UTVs work well on hilly ground. Until I got my UTV I used an old ATC 3 wheeler with a trailer. The 3 wheeler worked pretty well but on the hills around here it didn't have the weight needed to go down hills with weight in the trailer safely. Work 4x4 ATVs weigh quite a bit more than the 3 wheeler and would have been fine for my needs. An ATV will do most everything you need to do and for 10 acres may be a better fit as it will be more nimble. Do you have plans on using it elsewhere or will it always be on your land? This is the million dollar question. The nice thing about a UTV is that two can ride it comfortably. I often take the GF for a ride in the woods when it's hot out. I have lots of trails I can ride on thousands of acres. Some towns, counties, states allow the use of ATVs and UTVs on secondary roads. So you could find yourself using it to run to the store. A UTV would be much nicer if you need to run into town to get 5 gallons of gas and some milk. Either will work but you'll spend more for a UTV. I ended up with a UTV simply because it was a dealer demo and I got it for the price of an ATV. I like it and have no regrets but, as I stated, an ATV would also have worked fine for me.
/ ATV or UTV #15
Kubota RTV500 utility vehicle was designed to fit in the bed of a full sized pickup truck.
/ ATV or UTV #16
My neighbor has a Polaris Razor and it is very small and nimble, I don't care for them, but if are looking for a smaller UTV, it's worth a look.
/ ATV or UTV #17
I went from ATVs to golf carts to a Kawasaki Mule that seats four, but can be changed to sit two and have a larger bed. The bed dumps, which is really nice. My 70 year old Mom loves driving the Mule around the land, or just running to the mail box. With a set of removable seats for the bed, I can easily carry five passengers and myself on it, which is also very nice. Especially when older and heavier company comes over, who can't get around on their own very well. We use it to run down to the pond with ice chests or fishing gear, or to cut firewood and bring it back to the house. If one of the tractors breaks down, it's easier to make runs back and forth to the house for tools and parts then to drive a truck or to walk. The ATV did alright for this too, but it was always very limited on what you could carry on it. But the best thing about the Mule over an ATV is being able to sit side by side with somebody and carry on a conversation while enjoying the land. The golf cart was great for this and what showed me that upgrading to the Mule was the direction I wanted to go. Look at all the brands in your area, and decide if you want off road fun, utility work vehicle or a combination of both. The Mule can be fun, but mostly it's a utility work vehicle.
http://www.tractorbynet.com/forums/atvs-utility-vehicles/181191-barebones-mule-your-suggestions.html
This is the link to my thread on deciding what to buy, then some pictures of it and my modifications.
Good luck and have fun,
Eddie
/ ATV or UTV
Eddie
Eddie,
Thanks for the reply. I have been following your thread on the Mule plus another Mule thread someone else posted and I think that might be a good fit for what I need (want). I hadn't considered a 4-seater but I wasn't aware the back seats can be converted to increase the bed capacity. I assume this will increase the price so I will have to think about that.
Crazyal,
Thanks for your reply. I plan on keeping it in our garage while I am not there so weather will not be an issue. I do not plan on taking it anywhere else other than to be serviced if needed so transporting it won't be too much of a
concern. Our place is in NW PA but I am not sure what the local laws are regarding UTV's but I have not seen any others being driven around the area. All of the surrounding land is private property so I don't foresee driving it anywhere else than my property.
I am in NW PA and am within an hour of a Kubota dealer and 15 minutes from an ATV/Motorcycle place that sells Kawasaki Mules and another that sells JD. I will be there in August for a couple of weeks so hopefully I can buy something while I am there.
Thanks,
J
/ ATV or UTV #19
One thing I forgot to mention is that most (if not all) UTVs have real 2wd. The rear axle only locks the rear wheels together when in 4wd. This will allow you to turn much tighter and easier plus your lawn will thank you as ATV/ UTV tires will rip it up.
/ ATV or UTV #20
I've had my old 550 Mule for 14 years, I bought it over the ATV's because of the usability!
For my needs, if I were to buy a new one, it would be the 4WD 610 Mule, small enough to use around the yard, but big enough to do what I need at the farm. ~~ grnspot
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
UNUSED IRANCH IRTPL 10000 LB TWO POST LIFT (A64281)
UNUSED IRANCH...
2022 EZ-GO ELITE...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
UNUSED ATSPOWER PROPANE PATIO HEATER (A64281)
UNUSED ATSPOWER...
