Diesel Engine Oil
/ Diesel Engine Oil #1
LouieJunior
Moline, Illinois
JD4052R Open Station
I have a John Deere compact utiliy tractor with a Yanmar diesel engine. I've used SAE 10 W 30 motor oil -- although nothing specificly formulated for diesels. Now I see diesel oil is available, but my owners manual makes no mention of it. Does this matter?
/ Diesel Engine Oil #2
Yes - you should always run diesel oil in a diesel motor as the additives are different. Most major brands (Mobile, Rotella, etc) are all good and reasonably priced
/ Diesel Engine Oil #4
Yes you need a diesel rated oil in your tractor to handle the carbon-soot-.Any 15W40 motor oil will suffice.
However,you would be best served with Shell Rotella 10W30 motor oil,available at your local auto parts store as well as others.
/ Diesel Engine Oil
Thanks to all. I'll change it today. Hopefully no damage has been done. It was a little over a month ago when I put the other oil in. Seems like it has been running smoothly and the temperature has been normal. i'm guessing only 15 or 20 hours total.
/ Diesel Engine Oil #6
Should be fine - the diesel oil is made for the different conditions that exist in a diesel motor. If you ran it for 1000's of hrs then I would be concerned, 15-20 should not have harmed anything at all.
/ Diesel Engine Oil #7
Shell rotella is a good grade of oil for a diesel car or pick-up but Rimula is the shell equivalent to the diesel oils we sell for our tractors.
/ Diesel Engine Oil #8
15 or 20 hours won't be a problem. But I agree with the others, you should be using a diesel rated oil. I use Rotella.
/ Diesel Engine Oil
What does the operator's manual say to use ?
There is a chart showing different weights and temperatures.
SAE 10W-30 looks best for my use. The manual then lists john deere oils - PLUS-50 and TORQ-GARD Supreme
Other oils may be used which meet the following specification...
API Service Class CH or higher
ACEA Specification E3 or higher ??
that's all it says in my JD4105 Manual - it is a 2011
/ Diesel Engine Oil #11
Based on your manual, a CH, CI, CJ (and so on) rated oil, in the correct weight from the chart will work fine.
As time goes on the API reqirements are updated, and a new C_ rating is issued. Designed as backwards compatible, so the older C ratings tend to fall out of production. (The whole story is a little longer than that, but that is essentially what you need to keep in mind).
Stick to the big name brands (ex. Rotella, Mobil, Chevron) in a CH+ rated oil, until you become a little more comfortable selecting diesel oils. Some guys like JD oil, you should be fine with JD CH+ if you are going by the dealer anyway.
(Can't recall you location as I type.... if you use your tractor in the winter (northern locations) , starting is easier with a good synthetic.)
Good that you caught it now, but for a short run like that you should be fine.
Rgds, D.
/ Diesel Engine Oil
Thank again -- I'm going with the rotella since so many here have recommended it. Just drained the non-diesel oil out of the engine and I'm surprised how black it is after such a short period of time. Putting a new filter in too.
/ Diesel Engine Oil #13
I agree with all of the above...good advice! I personally am a fan of Rotella T6 5w40 full synthetic diesel oil. The nice thing about the T6 is no change is needed for extreme hot or cold temperatures and the T6 meets every diesel spec out there pretty much for all manufacturers (except my wife's VW Toureg diesel)
/ Diesel Engine Oil #15
beat me to it, I was going to say T6 as well.
/ Diesel Engine Oil #16
Yes, oils with a C classification are for compression ignition and oils with S classification are for spark ignition. A lot of C rated oils are also listed as S oils. The second letter is just the latest specification. i.e/ SH/CD
/ Diesel Engine Oil #17
As the engine probably doesn't have rolller cam followers. Use a HD diesel oil that is not supposed to be used on post 2007 diesel engines. The later emission diesel oil is a low ash product with fewer anti wear additives.
/ Diesel Engine Oil #18
That was the other part of the story that I was alluding to.
Even 10 years ago, chances are the OP wouldn't have had a problem, as many of the gasoline marketed motor oils were also C_ rated at that time.
FYI OP - many of the modern "Fleet" diesel oils of today (T6 being one example) are commonly rated for diesel and gasoline use (C_ and S_ ratings). That is one of the reasons they are popular.
BUT, few (if any) motor oils that are marketed for Gasoline motors today are diesel rated. You probably got that from the earlier posts, but it is critical enough that I wanted to re-state it.
I understand some of the science behind this agglomeration of oil specs that have been issued in the last decade. Still, I have to think, there must be a few reports lying around the Marketing departments of engine companies that detail the increased business these specs have created due to improper maintenance.
Rgds, D.
/ Diesel Engine Oil #19
guys, is there any reason a 15/40 would be preferable over 5/40?
Almost everyone associates 15/40 with diesel.
Let's assume no extreme cold, but plenty of hot.
I know in high temps it's the 40 one worries about, but
are there compromises in the oil to accomplish this?
Or is one oil simply formulated more "completely" to accomplish a wider variety of tasks?
/ Diesel Engine Oil #20
Realistically, and decent type of either grade should give you good service. I suspect you understand the cold benefits.
In terms of nuances, hot, I checked Amsoil to compare two synthetic versions of those weights. (What I'm trying to do is compare to equivalent base oils, as many 15W40's tend to be conventional). Long story short, the equivalent 15W40 has about a 12degC higher Flashpoint.
That higher Flashpoint should give you a slightly lower oil consumption under extended high temperature runs, esp. at high loads. My guess - if you were pulling a loaded cattle trailer all over Texas in the summertime, AND the motor was oil tight (no leaks) you might see the difference. Most people don't pay that much attention though.
Conventional oil, in a given weight grade, tends to have a lower Flashpoint than synthetic. If you know your road vehicle well, you can see this tendency (slightly higher oil consumption with conventional) esp. during the summer months.
Way back, the standard wisdom was that you didn't want too much of a spread between the top/bottom viscosity #'s. The historical reason was that the techniques used to get a wide spread weren't as good as what is the practice today..... long way of saying that modern oils (Conv. and Synth.) are better than they used to be.
That said, engine use and maintenance practice can be a factor. Assuming I didn't have to deal with cold temperatures, for somebody that changes their tractor oil every 5 years whether it needs it or not, I'd probably want to see 15W40 in there - but that is an extreme situation - most TBNers don't let things go that long.
Rgds, D.
PENDING SELLER CONFIRMATIONS (A59908)
PENDING SELLER...
IRANCH WOOD GRAB ATTACHMENT (A60736)
IRANCH WOOD GRAB...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
DRIVEWAY ENTRY GATES (A60736)
DRIVEWAY ENTRY...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
