62D Mower Deck - I'm tired of scraping it!
   / 62D Mower Deck - I'm tired of scraping it! #31
I have had very good results from painting the underside of the deck with POR 15. There was no paint left on the underside of my 272 when bought it, so I wire-wheeled the loose rust off, treated the bare metal with the recommended Metal Ready solution, rinsed and allowed to dry and then painted on the POR 15. That stuff is rock hard, very durable and provided a pretty slick finish when cured. I get very little accumulation of grass on the underside.
   / 62D Mower Deck - I'm tired of scraping it! #32
stop mowing wet grass and you wont have to scrape your fine paint job
   / 62D Mower Deck - I'm tired of scraping it! #33
Nooodles, grass has moisture in it self, Grass isn't like bone dry hay.
   / 62D Mower Deck - I'm tired of scraping it! #34
I think hes probably mowing it after a storm where it gets caked on the underside
   / 62D Mower Deck - I'm tired of scraping it! #35
Mowing the lawn on a sunny day still cakes up my mower deck, so why wouldn't it cake up anyone elses' deck.
Thanks for the recommendation. If the graphite paint doesn't last through the rest of the season, I give it a treatment of POR-15 this fall before I put it away for the winter.
Part of my grass is wet even if it hasn't rained for a week. In the shady areas where there are also some springs near underground, the grass itself contains a lot of moisture.
Exactly.
   / 62D Mower Deck - I'm tired of scraping it! #37
If the grass is green, it has moisture in it. If it had no moisture at all, it would be dead brown grass.
1999 Thompson H3 S/A Towable Vacuum Water Pump (A59228)
1999 Thompson H3...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2009 1770 NT 16R Planter (A59814)
2009 1770 NT 16R...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
208735 (A60430)
208735 (A60430)
