Backhoe Mount Failure on Ford 2120
   / Backhoe Mount Failure on Ford 2120 #1
srshaw3
Member
Gilsum, NH
Ford 2120 & John Deere 450B
I just bought a 2000 Ford 2120 with backhoe.
When I used it Saturday some welds broke on the mounts. These appear to be the only connecting parts between the tractor and backhoe. Is there something missing, or if not, is this a common failure, and what is the suggested repair?
   / Backhoe Mount Failure on Ford 2120 #2
Maybe a hair line crack to begin with. Would be hard to spot at first.
   / Backhoe Mount Failure on Ford 2120 #3
The failed area looks as if it had been repaired previously, maybe more than once. I'd try to find a frame mounting system that places less stress on these welds. I doubt a reweld will last.
How do you like the 2120 otherwise? Love mine, but have no backhoe to sour things.
Jim
   / Backhoe Mount Failure on Ford 2120 #4
Also take a real close look where the top link attaches to the tractor. That area might have taken added stress when the welds you show failed. Here's hoping no cracks appear.
There are many threads on TBN about frame-mounted vs. 3-point mount hoes.
Jim
Jim
I have only had it a few weeks, haven't done much with it. It has done what I asked so far!
Jim
I am wondering if it is missing the top link. I can't recall seeing one. If someone has a photo of one, that would help.
   / Backhoe Mount Failure on Ford 2120 #7
That installation does not use a top link, and you should not install one. That is not a common failure and must have been completely overstressed when it happened the first time. The initial repair was of poor design and execution. A quality welding job including well-thought-out gusseting and plating is all that is needed.
excellent, thank you!
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
JOHN DEERE LOADER LINKAGE (A52708)
JOHN DEERE LOADER...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
40' FLATBED TRAILER (A58374)
40' FLATBED...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
