950, 5ft bushhog overheating
/ 950, 5ft bushhog overheating #1
Anomic
Member
Front royal va
Shopping
So ive had my 950 for a couple months now (about 20hours) and love it!
Im concerned with the overheating im experiencing when bushhoging. Has never overheated when using it for anything else (box blade, dirt scoop, skidding logs etc)
When bushhogging i am
4wd (brakes are worn out and i have some slopes so it seems safer to help keep me from slidding downhill)
Have weights believe 25olbs on front bracket -- no loader
I usually run in 5 or 6th but have seen overheatting in all gears incuding 2-3 when im in tight areas.
I keep it at "pto rated" rpm marker which is 2150rpm
My field is 8acres and gently slopping. I can run the tractor sideways but like to do up and down to be safer
First cut it was HIGH 3-4' of weeds so i thought that was the problem. This time i hit it at 1.5' and still am overheating
80-90* ambient temp. Have tried working at dusk when its in the 70s but didnt seem to help
Ive usedmthe aircompressor to blow out the vent screens and all around the radiator it was not that dirty
Generall after 30-40 minutes running the dummy light comes on and i idle down and pop the hood open to let it cool down until light goes off usually 10minutes. Then i can run about 15-20 until light comes back on and i have to elt it cool down again!!! A real pain.
The raditor looks newer than the tractor but i have no idea how old. Fluidmin overflow tank looks clean and level goes up when it is warme up
So my questions are
Should the 950 be able to run the bushhog in those conditions without overheting or is it normal?
Is the dummy light accurate orr should i try to install a real gauge?
I tried running it in a lower gear and it dosnt help. Im at minimum rpm to run the mower so cant change operation.
Whats my next step.
/ 950, 5ft bushhog overheating #2
Just don't bush-hog any more! :p
Seriously now.
It's a small tractor, so it could just be overloaded with the 5' cutter. Have you tried just cutting half the width at a time?
If you've tried that, then it could be a mechanical problem. Here's a few items to check.
You have a 25-35 year old tractor. Could be something as serious as a stopped up radiator core, or as simple as a loose (or slick) fan belt, a bad radiator cap, etc. I would suggest a bad thermostat, but it most likely would overheat at other times.
It's really a shot in the dark. I've seen some really strange things cause overheating.
You need some real numbers on the temp. You could install a mechanical gauge, but it will be easier (and probably cheaper) to pick up an infrared temp gun. They even sell them at HF tools for about $30-40. It's a "no-contact" thermometer that you just "point and shoot." (can be used for lots of things) If you get the temp gun, check the temp of the engine block compared to the top of the radiator, compared to the bottom of the radiator, etc.
/ 950, 5ft bushhog overheating #3
I think an air compressor can drive debris deeper into nooks and crannies, thereby plugging things a bit more, just deeper and out of sight. So if using it, blow from the backside toward the front, not the reverse.
Well the fan pulls air really good its not that. Plenty of air coming across the radiator. But first thigs first am i asking to much of the tractor or should it be able to handle that work?
/ 950, 5ft bushhog overheating #5
Then I'd follow the advice Bigfoot gave, of trying to mow half swaths and see if it can handle that, without overheating. I can do with the 1050 what you are trying to do, but I have a little more power. So, I'd like to say yours can do it, but will need a bit of "troubleshooting" to know for sure.
I also mow down small mesquites and other 1 inch diameter trees. That is why I think your 950 should handle simple mowing. But I am just extrapolating here.
/ 950, 5ft bushhog overheating #6
I would also suggest trying to cut the grass a little higher for an easier drag on the bushhog and see if that helps,if it does i would think a 5' cutter is too much for the tractor.
Great now i have to buy a new tractor lol. Ill get a heat gun as suggested and see if radiator and motor are same temp. It takes quite a while to hog as is half stripes will take forever! I cut about 6" high and try to hit it before it get much over 2'
/ 950, 5ft bushhog overheating #8
It takes me several days to mow 31 acres. I usually run in 4th gear, because I think it makes a prettier cut, than the higher gears. I can always tell when I am close to finished sometimes, and kick it into 5 or 6. When viewed from the house, the swaths are obvious.
I deal with mole mounds, fire ant mounds and sometimes thick weeds and grass. I can still bog a little in 4th, but no overheating issues, if all grills are clean of debris.
Of course, a new tractor sounds fun! :D
If you cut half swaths, and there is no overheating, then at least you should have your answer.
/ 950, 5ft bushhog overheating #9
are we talking a jd950? if so i had the same prob once with my 950 5foot brushhog i mow on steap side hills, also grass about nee high and it was 90 degrees. i really didnt solve the prob i just mow when its cool in the evning never in 4weel.and havent had a prob so far.
/ 950, 5ft bushhog overheating #11
A 950 should handle a 5' cutter under those conditions without overheating.
Check the fan blades and belt.
If they are OK the radiator most likely needs cleaned.
My JD 850 was having overheat problems. I took the radiator to repair shop and had it cleaned inside and out. The overheat problem went away
/ 950, 5ft bushhog overheating #12
The 950 and 1050 have the same CID.The turbo is the only difference.The 950 has 27.4hp at the PTO,the 1050 has 33.4hp.Per John Deere specs the 950 can handle the 6ft. 606 rotary cutter.I don't think you need a bigger tractor.Maybe a cooling system flush,and a coolant temp gauge could narrow down the issue.A friend of mine has a 955 that keeps activating the idiot light under hard use,but the tractor has no other signs of overheating.
/ 950, 5ft bushhog overheating #13
I've been trying to figure out what make tractor it is too.
/ 950, 5ft bushhog overheating #14
I "assumed" a JD, because it is under the JD owning/operating section.
/ 950, 5ft bushhog overheating #15
The front of the mower needs to be adjusted about 1" lower than a back. That will decrease the amount of work on the engine.
/ 950, 5ft bushhog overheating #16
Your 950 should easily handle a 5' cutter.
As others have written, ensure that radiator is clean as well as the grill and side panels. I keep and old 2" paint brush (with the bristles cut down to about 1") in the tool compartment to clean those grills fairly frequently.
Since the 950 was used when you bought it, I suggest it wouldn't hurt to flush the radiator and check the hoses. You may know that coolant hoses have a reinforcement molded into them...and when the hose gets old, those reinforcement don't work as well. That can result in the hose collapsing and reduced coolant flow.
And, of course, check the thermostat...
/ 950, 5ft bushhog overheating #17
Take a look at the brush hog do you have anything wrapped up in it and is it spinning freely if your binding or have something in it it would cause it to over heat from being over worked.
/ 950, 5ft bushhog overheating #18
I can run my 950 4wd all day long with a 5' brushog with little or no effort on the tractor in 90 degrees +. Most likely you have a thermostat problem, radiator needs flushing, or some other cooling system problem. This thing could run a 6' hog just as easy. What and how you are mowing makes a big difference, but not enough to explain what is happening to you. I dumped the lights on mine and have gages. Tractor runs 175-180 all day long and never moves no matter what. Also, if you are still running the warning lights, could be the sender is bad. You got some sort of cooling system problem, you might check that out.
Chris
Well i got the infeared theomometer and here is what i got
Manifold 325
Block 210
Thermostat housing 220
Radiator (fins) 135
Top of radiator 210
I was only mowing the yard which is 1acre and i do it every week so its not that hard compared to the meadow. The idiot light did not come on.
/ 950, 5ft bushhog overheating #20
My JD870 was loading up pretty hard mowing 1.5' tall wet weeds today. Mowing in 6th gear. I would not mow that fast if I was going to be loading up my engine that much. Weeds got thinner after a minute. I would guess there is a fair chance you are loading up the tractor too much. On my tractor you can hear it load up and you can look at the exhaust changing colors as it tries to dump more fuel in to keep up the speed. Note that if your fuel filter and strainer are clogged your engine may run lean which means it will run hotter than normal. I have never overheated my 870 but my grass on my property never gets super thick as horse eat it down. Across the street nothing eating the grass so it could get thick and tall with enough rain.
My 870 has 1 more horsepower, or maybe a lot more as it only has 545 hours on it.
2007 Volvo VNL Truck Tractor (A63118)
2007 Volvo VNL...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
(4) ROW FIELD CULTIVATOR W/ROLLING FENDERS (A62130)
(4) ROW FIELD...
INOP/NON-RUNNING 2005 JCB Telehandler Lift (A61166)
INOP/NON-RUNNING...
Polaris Ranger 4x4 (A61166)
Polaris Ranger 4x4...
40' CONTAINER (A62131)
