Tires What size tire?
/ What size tire? #1
Tipptop
Georgia
Ford B 3000
Hey guys! I have an old Ford 3000 tractor that I use to mow my back field. I inherited it with the house I purchased last year. The front right tire has a slow puncture in the side of it. It's a tiny "crack" in the tire maybe a centimeter wide and less than an inch long. Can I fix it or do I need to buy a new tire and what size do I get? Thanks for your time!
/ What size tire? #2
According to tractordata.com the Ford 3000 uses a 5.50x16" front tire. I would check what it says on the sidewall of the tire and go from there.
I am guessing the front tire has a tube and that it is leaking. You may have punctured it through the side of the tire. You can always try tire slime to see if it helps but if it is really bad you may need a new tire and tube.
/ What size tire?
Thanks so much Creek! It's a very old tractor and I don't have a way of transporting it to the nearest service garage which is roughly 7 miles away. I know very little about tractors.
/ What size tire? #4
Can you jack up the front and just take the wheel off to get fixed, or do you not have a good jack and stands? Some tire service centres will come to the farm to replace the tire. Would add a bit to the cost, but if that is what is needed...
/ What size tire? #5
If it has a tube as one would expect the slime would be an option. Flat Fix I find does not work as well on a slow moving vehicle but you could try it. The other option is just air it up when you want to use it. That is a common 'solution' on old stuff.
If you have not changed the oil and filter in the engine I suggest doing that if it does not look new like too. Personally in stuff that seldom starts I may go 5 plus years between changes if it keeps looking clean but I know others who change oil even if the engine was never started for a year.
/ What size tire? #6
I know what you mean, but water can be hard to see on the dip stick unless you pull the drain plug from the oil pan, or other oil resevoirs (final drives, transmission, etc). I try to change engine oil every year, even if it gets little use, but to save money on some machines I might go 2 if it doesn't get too much rain or humidity.
Tipptop, you can check out TractorData.com Ford 3000 tractor information for some more details on your tractor. They won't have all the information you need, but it might provide you with some information that might be helpful now or in the future.
/ What size tire? #7
LT tires were used also... Really need to read the sidewall.
/ What size tire?
I cannot jack up the front but I have a friend who may be able to do it for me. How much will it cost me to get the tire replaced? I think it is tubeless, because the air is coming out slowly through the tiny hairline crack on the surface of the side of the tire. But what do I know?
/ What size tire?
Ok, it's a Ford B3000, made in England. 2.9L Diesel engine. 8-speed. I have the original manual at home but I'm not there right now.
/ What size tire? #10
See if they can patch it from the inside.
If they are in really bad shape due to age if you could find some newer used 6.00 x 16 passenger tires that would be an option. It is the last number that is important. They can be 5.50, 6.00, 6.50 or something similar in the newer metric numbers. They will not look as good but will keep the rim off the ground. :)
The last front tires I bought were not cheap.
A big patch on the inside (boot is an old term some used) could let you get a decade or two more life out of them perhaps. :D
/ What size tire? #11
It might be tubeless, but it might have a tube with a small hole in that spot or somewhere else which is leaking between the tire and tube and exiting through that crack...hard to say.
I recently paid $70 for a new tire and tube for my Farmall A, but I had to install them. I think they were 5.00x15's so a bit smaller. This is up in Canada so the parts might be cheaper, but you are looking at labour to reinstall although that is quick.
But like Gale said, I would look at getting it patched or you could find a used passenger car tire where the tread has worn down to unsafe limits for car use. You could ask the tire shop if they have anything old or used they would mount on your rim for a bargain.
/ What size tire?
Very very helpful, guys. Thank you. A friend just recently got his two front tires replaced on his John Deere for $250. I'm not sure I want to put brand new tires on my 40 year old tractor lol!
/ What size tire? #13
The Farmall A I put those new tires on was over 60 years old now, it all depends on the condition of the tractor, not so much the age. ;)
/ What size tire? #14
if you don't even have a jack.. sell the tractor now. this is an ez fix.
partially dismount tire.. doesn't even have to come full off the rim...... stick a patch inside tire to cover damaged area / protect tube .. put in a new tube.. or patch the tube if it is new and you are low on cash.... remount tire onto rim being carefull to not pinch tube with tire or irons.. and make sure the tube valve sticks out the hole in the rim. capture it with a valve fishing tool.. or a clip on air line holder like from a tire pump.
as mentioned. tire can be anything from 5-6.5 and S/L/T series.. or a truck tire.. might find a tube..might not on a truck tire.. etc. I'd tube it if it did not have a tube...
/ What size tire? #15
You very well might be best off to take both fronts to a used tire dealer, and get some 225/75r16 load d or better E
Around here that's about $25-30 per tire, about another $5-10 per to mount (no need to balance), total price less than $75. If you are able to spend $200-300 you could easily get two brand new 3 rib fronts.
Right now on eBay, $192 buyout gets you two 7.5-16. 3 rib With tubes shipping might be ~$25-50, and a independent type tire Guy/trailer shop will mount them for probably less that $30. Total price for 2 bran new tires, shipped, mounted on your rims, about $272. Good to go for another 20 years
/ What size tire? #18
Is that 1cm x 1in, or 1mmx1in?
A cm wide crack is pretty large for a front tire. A mm would be reasonable for moderate to severe weather checking.
If it is still holding air, it can probably be patched, assuming the problem is with a tube. However, if it has very bad weather checking, I'd probably go ahead and get new tires.
For vehicle tires, I've been watching Craigslist for narrow 16" tires for some time for a pickup project. They do show up occasionally, at least around here. But, not that frequently. Perhaps I'll see them once a year or so. I think I did eventually find a pair of 6.50x16, and four 6.00x16 tires, for about $25 each. Otherwise, new vehicle tires can be rather spendy, and not necessary.
There is also a temporary tire, T155/90D16, 60PSI. You might be able to score a couple very very cheap at your local junkyard. Perhaps $5 to $10. I certainly would consider them for occasional light field & yard use with a tractor, but not heavy brush use, or lots of tractor use. Perhaps as a temporary stop-gap measure.
Anyway, if you have patience, and want car tires, just keep your eyes open. If you need AG tires, then you may also find them on Craigslist, or at your closest Tractor Breaker (also probably has rims). But, you may be best off just going to a local tire store and buying new. You may have troubles finding good, super-narrow ag tires.
Ahhh... here are some numbers.
For "new" vehicle tires, 6.50-16, $124 to $143
Tornel Hwy 6 Ply - 650-16 - Military & Truck - Tire Applications
STA Super Transport - 650-16 - Truck - Popular Tire Applications
6.00-16 $181
Firestone Knobby Truck Tread Blackwall - 600-16 - Truck - Popular Tire Applications
New Tractor tires are much cheaper, and perhaps easier to find.
5.50-16, $60
6.00-16, $62
FarmTireStore.com
Anyway, talk to your local tire store before buying them online. They can probably source them for you at a similar cost, and they will much prefer mounting their own tires.
I got a 4.00-9 tire from my local store. It took them about 1 day to find it.
/ What size tire? #19
Any local garage that does tires should have some 'good, used' lying around.
/ What size tire? #20
The standard equipment front tire size for a Ford 3000 is 5.50X16 but many have the optional 6.00X16. Unless retrofitted, these tires are tube type.
A new tire will cost around $65 - $75 and a tube aroound $20. A tire shop will likely charge around $15 to dismount/mount the tires, however many will mount without charge if you buy the tire and tube from them.
Remove the front wheel and take it to a tire shop that sells Ag tires, unless you have the proper tools to dismount/mount the tires yourself.
SDT
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2001 Freightliner Allegro Bus Class A Motorhome (A61574)
2001 Freightliner...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2016 Ford F-150 Ext. Cab Pickup Truck (A61573)
2016 Ford F-150...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
