hydraulic Oil
/ hydraulic Oil #1
Bubbit
Menlo Georgia
Kubota M7040 with loader
Any thoughts on reusing hydraulic oil that is strained through a t-shirt to collect dirt and other deposits. I was completing the 50 hour maintenance replacing the two hydraulic fluid filters. I purchased 2 gals of oil from my Kubota dealer. I had a bit of a challenge getting the second filter on and lost more than the 2 gals before the filter was secured. I strained the oil that was drained into a pan through a t-shirt and it looks pretty clean. Was wondering if I am ok or created a problem by reusing the oil in this manner.
/ hydraulic Oil #2
so you're trying to save buying an additional gallon or two to top off what you lost in changing filters by straining the initial factory change through a tee shirt?...... how much was the original investment?..... :confused: best :)
/ hydraulic Oil #3
Consider the cost of a pump, cylinders, valves, filter, and the trouble to R&R them against the cost of a couple gallons of fluid. Your choice.
You don't know frustration till you've worked on a valve manifold.
/ hydraulic Oil #4
My thoughts.... no way! I would never do it. It isn't worth it. Buy a couple more gallons.
/ hydraulic Oil #5
Whats the difference if it was drained out and strained vs just left in during the filter change? Please, someone fill me in here?
/ hydraulic Oil #6
is this a rhetorical argument or are you for real?....actually you're saving $ anyway since you're not replacing the hyd fluid, basically just the filters. for the sake of a forum discussion, you might post this in the oil/fuel/lubricant forum. it is worthy of discussion, but are you willing to risk your new equipment for the cause? best wishes
/ hydraulic Oil #7
Wondering for real.. If you left the oil in (most of it anyways) and did just a filter change, then why would it be catastrophic to put some used, strained, oil back in?
For that matter, even when you do change the oil out, you never get all the oil drained so have old oil mixed with new anyways. What would the harm be in putting a little back in if needed?
When you change the oil in a automatic tranny only 60% or so of the oil is actually changed. Yet no one says its 'bad'..
/ hydraulic Oil #8
guess my concern would be contaminants no matter how careful one is to attention to detail. just about everything in life is risk...& i seem to err to caution which is indeed costly....your call & enjoy your new tractor, it's a good one!
/ hydraulic Oil #9
What you need to be worried about when reusing hydraulic fluid is the very small particles in the 2 to 20 micron range. You would need a special filter to filter out those particles. Your normal filter only filters down to the 20 micron range because the filter has to allow the fluid to flow at a certain rate. If you never wanted to change your hydraulic fluid install a bypass filter in addition to the regular filter. A bypass filter only filters a small percentage of the fluid at a time and is not restricted by the fluid flow requirements of the system and can filter down to 2 microns. Of course, once the bypass filter is installed, it is good practice to have the fluid analysed periodically to ensure the fluid is still viable.
Other than installing a bypass filter, change your hydraulic fluid with new fluid when specified.
ops. I should have read the opening post better. Personally I'd reuse hydraulic fluid that was drained into a clean container. I'm not particulary worried that there would be some major contamination in the clean container.
/ hydraulic Oil #10
I think tomf stated half of the only way I would reuse oil in my very expensive L45, if it was drained into a clean container that I was sure of no dirt or grit and I had no other oil available. I will admit I have changed a many rear end gear at the race track where we drained the oil into a dirty pan and poured the oil back in as needed thru cheesecloth. Never had any problems.
/ hydraulic Oil #11
On all of my Kubotas have done the 50 hour and changed all the fluid and after comparing old and new thought it was worth it. Let it settle out in the pan for a while and poured the top off and there was quite a bit of fines left in the remaining fluid.
David Kb7uns
/ hydraulic Oil #12
I replace all fluids when due with the appropriate Kubota fluids and filters. At the cost of the equipment it is not worth risking anything! I wonder how many microns a T shirt filters at?
/ hydraulic Oil #13
Silly me, here I thought the question was if the t-shirt could then be reworn ?
/ hydraulic Oil #14
I drained all the oil in mine at the 50 HR even though the manual stated at 400 HR. After seeing what was in the strainer and filter plus the debris in the drain pan I was glad I had. No way would I reuse just by straining. Dump it all now and chage it all, you may be glad you did.
Ron
/ hydraulic Oil #15
Just a quick question. I had a B7500 and remembered discarding all the fluid when doing the 50hr service
Looking at the service manual for my new L2501 it says just change the filter
I plan on draining ALL the hydraulic fluid and replace with Kubota 鉄uper
I知 I wrong?
What痴 $100 for a 5 gallon pail to protect your investment
Ray
/ hydraulic Oil #16
You can sure strain it. But...it's gotta be thru an American Made all 100% cotton (US grown cotton) T shirt. Then it will work good.
/ hydraulic Oil #17
If you are worried about throwing it away, I use mine in the chain lube tank on my chainsaw to lube the chain. Also works good to prevent rust on metal surfaces & don't have to worry about contamination in gear boxes & trans..
/ hydraulic Oil #18
Also mix 1/3 SUDT with Bar Oil in winter for the chainsaw. The MF35 also gets the settled oil.
David
UNUSED RAYTREE RMLL60 - 60" POWER RAKE LAND LEVEL (A62131)
UNUSED RAYTREE...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2023 Kubota Z252KH-54 Zero Turn Mower (A63118)
2023 Kubota...
2016 Ford Expedition 4x4 SUV (A61569)
2016 Ford...
1977 FURNAS BANDSAW W/AUTOMATIC SHARPENER (A62131)
1977 FURNAS...
2008 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A61568)
2008 Chevrolet...
