Rotary hay cutter
/ Rotary hay cutter #1
7879fordman
Gold Member
gillham arkansas
1969 massey 135 and a 2013 m7040hd 4x4 2013 L3800 HST 4x4
How big of a 3 point one can I use on my m7040 .
Sent from my iPhone 5 using TractorByNet
/ Rotary hay cutter #2
10'3" but if it was me I'd spend the extra $$$$ and get a towed machine or put the 3 pt on a caddy. I've got a 9'3" on a M7040 and had to slow down to 4th gear to cut some grass.
/ Rotary hay cutter
I think I'm just going try and buy some used stuff . Since I never cut and baled . And I just need to be able to cut 100-150 a year . Would just get it cut but i can seem to get anyone to do it . So thing I just buy some used stuff that I don't have a ton in to start and go from there . I missed a 7' cutter for $800 that looked to be a deal but wasn't sure . And I couldn't get away to get it and someone beat me to it .
But wasn't sure the size I should be looking for .
/ Rotary hay cutter
Pull behinds are hard to find around here as people are just starting to use them .
/ Rotary hay cutter #5
Are you talking about a rotary cutter aka: bush hog or a disc type hay mower? I don't think you really want to bale hay that has been cut with a bush hog.
/ Rotary hay cutter #6
Theres is an old timer i know that cuts extremely thick hay with a bush hog, but he can take the side off of his bush hog.
/ Rotary hay cutter #7
We used to have one of those. You left the side on and it was a rear discharge bush hog. You took the left rear side plate off and it would cut the hay off and fling it out the side without chopping it up. It was a Corsicana brand.
/ Rotary hay cutter #8
Around here the preferred tool would be something like this, a disc mower conditioner, and when you can pick something like this up used for $9K it was a no-brainer.
/ Rotary hay cutter #9
Are you Mowing 150 Acres on Baling a 150 Bales. If the latter, look at at the Drum Mowers. I just bought one and am extremely happy with it. It's a smaller acreage mower though, but the inertial cost can be about a third of the Disc mowers. bjr
/ Rotary hay cutter
Rotary disc hay cutter .
/ Rotary hay cutter
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=322560"/>
People are just started using them around here . So no used ones really on the market yet . So I will probley have to get a 3 point hook up one .
/ Rotary hay cutter #12
They not that bad once you get use to the three point hitch. I use to cuss mine out, not bad hooking up but unhooking. I have a JD 275.
Sent from my iPhone using TractorByNet
/ Rotary hay cutter #13
I use a 7'11 Vicon disc cutter on my 7040 handle it no problem,don't run a loader when cutting,if was any heavier would need to leave it on or front weights.
/ Rotary hay cutter #14
Mower conditioners seem to be very popular around here for both big time and hobby farmers. 1 machine to do the job of 3 seems like a no brainer to me. Things seem to be done so much different here than everywhere else. Here you cut with a mower conditioner then bale it when dry enough, from what I've seen other places mow it then ted it to help it dry then put it into rows with rakes then bale it, seems like a lot of work to make bales.
/ Rotary hay cutter #15
corey9212
In the last few years the humidity has gotten so high(most of the time) that if hay was to be windrowed right as it was cut it would never get dry. I lay all my cut hay flat then I rake three 9 ft cuts together and bale. You cut then bale. Who do you think makes more trips around the field with a tractor me or you?
/ Rotary hay cutter #16
corey9212
I guess the humidity here is still low then (although for quality of living higher humidity would be nice cause the air gets ridiculously dry) but that's all I see around here is people cutting with mower conditioners and baling a few days to a few weeks later, plus mower conditioners have a set of grooved rollers in the middle (not sure the technical name) that crimp the stocks helping them dry faster. Yes when you bale you get to make less trips around the field but how many trips around did you have to do to get it to that point to bale it, that's my point I was making.
/ Rotary hay cutter #17
Ok one trip less than your way. un-raked hay you make 6 trips around field cut(3) and then bale(3)=6. My way I make 3 trips to cut,1 trip to rake & 1 trip to bale = 5 trips to complete the baling. Also my way completes a field A LOT faster and that's important on fuel saving,labor,wear on baler and really important "IF a thunderstorm" is headed toward hay field..
/ Rotary hay cutter #18
If? Around here, its generally a "When" not an "if"
Aaron Z
/ Rotary hay cutter #19
Yay more time in my new tractor, lol. But in reality I guess it boils down to personal preference and location?
Aaron Z
Lately it's been "if" for when the sun will shine and things dry up.
/ Rotary hay cutter #20
LOL sounds WAY too familiar. We have the dryest 2/3 (ie: driest ground) of the lightest (ie: thinnest grass growth) of our hayfields cut right now, hoping it will dry enough to bale on Sat before the 30% chance of scattered thunderstorms shows up.
Aaron Z
213085 (A64276)
213085 (A64276)
UNUSED PARBREAK RT140-72" ROOT RAKE (A65055)
UNUSED PARBREAK...
1997 Volvo WG Day Cab Truck Tractor (A64194)
1997 Volvo WG Day...
2004 Chevrolet Trail Blazer 4x4 SUV (A64557)
2004 Chevrolet...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
Genesis Rescue Tools with Power Unit (A64553)
Genesis Rescue...
