California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,685
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
There's a LOT of valuable information on that page.
*Engine temperature only around 170 in the sort of use that is typical for us.
*Temperature only 201~210 at continuous maximum HP output. I doubt anyone here is powering a ditch pump or similar continuous wide-open throttle load, so we shouldn't ever see over 200 degrees with a cooling system that is up to spec.
*Tractor weight measured before ballast 1950 lbs. This is a little more than we have seen in other charts for YM2000/YM240.
*And as noted, it weighed 3305 lbs after prepped by dealer for this test - far beyond Owner Manual specs. So we would need similar ballast to make it pull like an 8N or similar 3000+ lb tractor.
* Maximum pulling power is at 2 mph, but only half of that at the 5 mph that I've read is optimal for production farming - discing etc - where you want to cover a lot of ground before dark.
* Lots more.
