Hay elevator chain
/ Hay elevator chain #1
rd_macgregor
Prince Edward Island, Canada
Kioti DK45SC, Kubota B2650
Last summer the chain on our 30' Little Giant elevator (model P1656) broke. The internet is not helping me much in tracking down some matching links to repair this.
Any suggestions??
BOB
/ Hay elevator chain #2
Should be detachable link chain, they have it on the shelf at our local tractor supply. I think mine is #55 but they have several sizes, best to bring a couple of links with you.
/ Hay elevator chain #3
Back when I worked for a JD dealer I regularly sold the detachable chain links in several different sizes.
/ Hay elevator chain #4
Any suggestions??
BOB
55 and 65 chain is common, however, as said, take couple links with you when going to buy new. Ken Sweet
After talking with my supplier, I agree... now to see about getting a link or two separated from the rest...hammer sideways, right?
BOB
/ Hay elevator chain #6
BOB
The correct link holding tool makes detaching links a lot easier. Worn chains are much,much easier to separate than new links.
/ Hay elevator chain #7
Yup, flex the chain to where the side of one link lines up with the slot of the other link. To make life easier there is a tool you can buy at most farm supply stores for around $20 which helps hold one link while you beat the other link loose. I made mine from a 4" length of 3/8" x 4" angle iron which I used my chop saw to cut a groove into it the depth of the width of the chain link.
I will attempt to attach a picture of the store bought tool.
John
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
HOMEMADE 14' - 3 REEL TRAILER (A63276)
HOMEMADE 14' - 3...
1989 STE 307 SS 4 Comp Non Insulated T/A Chemical Tanker Trailer (A64194)
1989 STE 307 SS 4...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A65055)
UNUSED RAYTREE...
