Stump Bucket
/ Stump Bucket #11
If dead stumps they won't be bad. They root shallow. Something like the bucket you pictured will work. If you noticed in the video, he's also digging out a dead tree/stump. It'll still be a LOT of work and time. We have a T300 Bcat like the one pictured. They are a workhorse as seen in the video. More effective at this type of work than a skid type. But it'll definitely give you a project for this Summer. We want pics when you get started of course.
I liked that stump bucket design. In watching the pushover attempts I was surprised to see that the T300 used could not slip its tracks. Do you find that on yours as well ovrszd?
larry
/ Stump Bucket #12
larry
I'm sorry I don't have a pic of our tracks, but they look more like an All Terrain tire design. Small, broken up blocks of tread. They get awesome traction. The only way it will spin is in mud. Sod or good dry dirt, it won't spin, it'll try to stall instead. When using the tree puller I made, if it won't lift the tree straight up out of the ground, forward and backward movement will usually bring it out. With that said, you gotta be careful, puts a tremendous amount of stress on the attachment and/or the Bobcat. A tracked Bobcat is SO much more productive than the skidsteer version on tires.
/ Stump Bucket
Wish I had the T250 rather than the S250, but I will make due.
/ Stump Bucket
The curve acts like the claw of a hammer allowing you to use the weight of the machine to pop the roots out. Only problem is the jarring on the joints once the roots snap. I think I should learn more like the video, to break the roots by digging the point down deep and moving foward rather than using the weight of the machine. Maybe the opperator in the video is smother because the tree is dead
/ Stump Bucket #16
Here's mine that I designed.
/ Stump Bucket #17
If dead stumps they won't be bad. They root shallow. Something like the bucket you pictured will work. If you noticed in the video, he's also digging out a dead tree/stump. .
I saw it was w/o leaves, but couldnt tell the season. Leaves were not apparent on any identifiable hardwoods.:confused3:
larry
/ Stump Bucket
Did you build this. This what much like my original intentions when I wanted to build rather than buy. I am glad I bought one cause I can tear up an anvil
/ Stump Bucket #19
Yes... Machine shop built off my prints. The scoop is made on a rolling mill.
/ Stump Bucket #20
I bought one with teeth in the front from another member. It's not as obviously rugged as the ones in the videos, nor did we have much HP to ding it up as we each did in turn. (40 & 35) What we with CUTs have to recognize is the labor & mess that's still needed to get big stuff loose with such an implement. I'd bet there's some track spinning not shown in the vids, and my R4s will spin a bunch without some lunging momentum when going under in the softest soil.
My NH loader will barely pop a one inch root if there's a few smaller ones in the way, & I pried hard enough to bust welds (poor ones at that) on the bucket's top QA brackets. (hardly a HD version, too) My most effective force is when leveling the bucket's bottom & teeth and piling in at waist-high or so to loosen 'em up in sandy soil. (4" or less trunk dia) another such hit or two right at the base will often tip them & rip the far roots loose. I've had several hang up on the teeth and just backed them to the burn pile whole.
My tall targets are typically (s__-)elms. Most others are autumn olives say 12'x12' with 1/2 doz or so branching 1 1/2" mains. If I had any typical soil my work would be easily twice as difficult. My point in all this is that these atts need a lot of traction and effort at best. IMO they're for guys with serious o'all power above all else, & I'm sure ovrszd, gr8bldr, papa perk and Xfaxman would agree.
pp, nice design there. :) btw: IIRC the CUT-driving member I bought my bucket from will be grinding his stumps from now on. ;)
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
DSP 900 Balancer with Split Weight (A61307)
DSP 900 Balancer...
2018 International WorkStar 7400 T/A Lely 4,500 Gallon Septic Wet Vacuum Truck (A61568)
2018 International...
MAGNUM PRODUCTS LIGHT TOWER (A60736)
MAGNUM PRODUCTS...
2020 John Deere 26G (A60462)
2020 John Deere...
John Deere 6110M (A53317)
John Deere 6110M...
