potato digger
/ potato digger #1
klug
Member
romania
atv
Hi all
I need a sketch, plan to build a potato digger
thanks!
/ potato digger
yes,a potato digger!
thanks
/ potato digger #5
I'd just browse photos on the internet until you find something that looks like it will suit your needs. Then copy it and customize it to suit your needs.
It looks like many of the older systems had a complex conveyor system, but many of the newer ones are designed to simply pull them up and leave them sitting on top of the ground for someone to come and pick up. And the whole system may be quite passive.
/ potato digger
I know how it should look, I need give a diagram with dimensions!:thumbdown:
/ potato digger #8
How much is the Herman Jones potato digger?
Looks pretty neat.
/ potato digger
Looks like they run between $400 to $700. I think one could be built for about $175 plus labor.
Products
Yes, it's simple ... maybe I was not clear, I want to be driven by the PTO
thank you,
/ potato digger #12
You may find someone here that has made one of the potato diggers. Or, if you're lucky, a farmer in Idaho that is actually using one.
However, I doubt you'll find a detailed CAD drawing. And, you seem to have some specific ideas, and are already rejecting the ideas posted by others without giving much input of what you want.
Why don't you post some details about your potato planting operation, acres or hectares, perhaps your tractor, HP or KW, and some details about the digger you have in mind. Then, perhaps people will come up with suggestions of how to progress.
/ potato digger #13
From what I have heard...Potatoes are not good for you...full of useless carbohydrates and starches, sugars and such...Not Good...converts your other calories into fat by increasing insulin...can cause diabetes....Leafy green veggies are much better for you and you won't need a digger....:thumbsup:
/ potato digger
Ok, I have a tiller with PTO and want to use this potato digger ... I cultivate areas that are low
The idea is that I want to build I did not buy it, that's why I'm looking for drawings
Thank you!
/ potato digger
Thanks, thanks for the advice but I know these things and ... I do organic farming on a small farm
Thank you!
/ potato digger #17
Thank you!
Do you want to use the tiller as part of the potato digger?
/ potato digger #18
Why not buy an old ground driven digger for cheap and convert it to run off the tractor's hydraulics or pto? In the end you can still get the machine you want but will save a ton of money vs trying to buy all the components new. It will also give you a working reference point to start your custom build from.
My neighbour has one that he built this way and ot works very well. If I can find a picture I will post it.
/ potato digger
Off, I need a sketch with dimensions etc...and ... I said I want to build one ... is my pleasure.For example will attach a link to clarify the problem!
05092010025 - YouTube
thanks!
/ potato digger #20
Ahhh, a walk behind tractor.
I was thinking of a larger tractor.
Russian? You might have troubles finding specifics about that machine in the USA.
Following some of the links, this either is the manufacturer or a vendor of similar diggers.
I found this page showing a homebuilt digger. It has a 3pt version shown at the bottom of the page, along with parts diagrams for that one. Perhaps you can find the parts diagrams for your target machine.
The "shaker" undoubtedly helps with the separation of the dirt from the potatoes, as well as aiding with the cutting (probably vital for a walk behind tractor). You would need to design a frame that doesn't move, and the cutting head and separator that does.
Are these machines patented? A lot of info is available on the patent pages.
However, keep in mind that ultimately you will be making your own machine. You don't necessarily want to copy exactly a commercial version. but take some of the ideas from several ones you see.
These all have an adjustable depth.
Width may be dependent on how you plant your potato hills, as well as the design of your tractor/tiller.
2016 Ford F-150 4wd 4 Door (A63118)
2016 Ford F-150...
2025 Anvil 12 ft S/A Enclosed Trailer (A61569)
2025 Anvil 12 ft...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
New/Unused Landhonor Quick Attach Power Rake (A61166)
New/Unused...
