Grapple Titan 48" JD quick attach grapple.
/ Titan 48" JD quick attach grapple. #1
dusty3030
West TN
Kubota MX5400 Cab, Kioti RX7320 PS/ Cab, Kubota M7040 HDC, John Deere 2355, Kubota U35-4, John Deere 317G
Picked it up yesterday at Titan warehouse in Collierville TN. Brandon was who I had spoken to on the phone and he loaded me up. Great to deal with and if you have an opportunity to go pick up in lieu of shipping I suggest you do it, it worked out well.
These babies were stacked to the ceiling as well as were the skid steer attach grapples.
Seems well built. Pivot points are greaseable pins.
Fit on a 400x loader perfectly.
Found the quick connects I needed at tractor supply for $20 for the set, hooray.
Finding a solution to get from the 1/2" pipe thread or the whatever the **** the hoses crimped on connector was to a 1/4" male to use the right pioneer coupler to hook up to deere's hardline kit is more challenging. I will post more on that at a later date. A hydraulic shop is going to be the best solution and I will post on that when I do the final fit, I used brass reduction fittings from Carquest for the short term cause that is all I could get on Memorial Day weekend round here.
I will wash the tractor and do better pics tomorrow.
Here is the grapple and the card on the pioneer couplers from TSC. Also included is a fine Kansas City Memorial Day weekend beverage.
/ Titan 48" JD quick attach grapple. #2
Lookin good, You think it might need a third tooth?
Haven't used it enough to know better, I have some stuff lined up so when it dries up a little I'm going to give it a workout.
/ Titan 48" JD quick attach grapple. #5
Nice root grapple and $20 a set of couplers ain't bad either. I just paid $150 for a set of flat faced couplers. Total for two 1/2" hoses 7' long for a new stump bucket grapple cost me $280 at the JD dealer.
/ Titan 48" JD quick attach grapple. #8
The only problem with your grapple is it looks a little green;). Actually it looks good, did you paint it or do they over it in colors other than black.
The JD quick attach grapples come from Titan in JD green.
/ Titan 48" JD quick attach grapple. #10
So how did your tractor handle this unit...?
Like a charm so far.
/ Titan 48" JD quick attach grapple. #12
oes anyone know the weight of this unit...?
went to the webite but id not see it listed.
View attachment 323287Here is a picture of the coupler. I went from their supplied 1/2 pipe adapter, put on a 1/2 to 3/8 reducer then a 3/8 to 1/4 reducer then the 1/4 Pioneer quick connect set I got from TSC.
Not the best, may not be forever, but I have decided to roll with it until it breaks if it breaks for now.
/ Titan 48" JD quick attach grapple. #15
i just ordered a john deere 3320 it will be in in 3 weeks its gonna be my first tractor with exception to driving my grandfathers ford 5000 with box scraper i purchased the grapple from titan also just not sure how or what to buy to make it work i went to everything attachments they want me to pay 1000.00 for a third hydraulic but i read about an 300.00 under the seat 3rd svc hydraulic not sure if thats already on tractor or not how did you make your grapple work and is there a website on what you bought and how to hook it :confused2:up
/ Titan 48" JD quick attach grapple. #16
Can someone give me a current location to find one of these 48" Titan grapples for a John Deere 300cx loader? I need one with JD hooks and pins. (I cannot locate one that is not Skid Steer QA.)
Try this link, this is what I have. Other sizes too look under attachments for John Deere tab/ grapple buckets.
48
/ Titan 48" JD quick attach grapple. #18
@Foggy You can see all of our Deere Style grapples here: Attachments for John Deere Call me directly with questions or to place an order over the phone at 800-605-8241
@dusty3030 Thank you for the great feedback! :thumbsup: If you need more pioneer couplers we now have them available here: 1/2" Pioneer Hydraulic Quick Couplers (1 pair)
Craig
800-605-8241
/ Titan 48" JD quick attach grapple. #19
I am very happy with my Titan FEL-mount 3 point attachment adapter :)
Although, I am not using it for the purpose it was designed for, I am using it to shove implements backwards.
[drop spreader on the FEL, running backwards]
At some point, I will get a lawn plugger for the same position.
2017 Nissan Quest Van (A61574)
2017 Nissan Quest...
SCREVEN MACHINE & TANK CO (A64280)
SCREVEN MACHINE &...
2023 KMC 3pt 6 Row Rolling Cultivator (A64119)
2023 KMC 3pt 6 Row...
2015 HAMM H11IX PADFOOT ROLLER (A64279)
2015 HAMM H11IX...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
2012 Case SV300 Skid Steer (A63111)
2012 Case SV300...
