John Deere 6420 Auto Light is always on
   / John Deere 6420 Auto Light is always on #1
Uffelmann
Red Bud, IL
CIH MX 285
We have a John deere 6420 and the auto light, located near the PTO lights on the right of the cab, is always on. I cant find out what it means or why it came on. Our tractor still runs the same. Thanks for the help.
   / John Deere 6420 Auto Light is always on #2
Trans is in auto shift. Look for a button at the rear of the gear range knob. Press the button and light should be off and auto shift will be off.
   / John Deere 6420 Auto Light is always on #3
I would just pull the fews when you don't need them on. Old trick my pappy showed me his gravely walk behind
   / John Deere 6420 Auto Light is always on #4
Im guessing you have a IVT Transmission in that 6420. I think its in Full Auto mode. You could try putting it into manual mode and that should take it off. But it would drive like a regular tractor. Instead of it being in the Full Auto Mode. Hope that works.
Not to be rude but... whats with your random posts? This isn't a tractor you just pick up at Home Depot.. Pull that fuse out and you'll probably have a caution indicator flashing at you all day. :duh:
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
2014 FORD F-250 (A50854)
2014 FORD F-250...
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
