Utility sized tractor picutures
/ Utility sized tractor picutures
Thanks Piston. The machine is upstate so it'll be a few weeks before I will be up there next to play with it but I'll be sure to get some more action shots. As for the model..it's the Mahindra 8560. I have a GOPRO so I want to start making videos to satify a fix when I can't get up for weeks to play.
I know exactly what you mean about the video. I take a lot of pictures when I'm on the tractor for the same reason you stated. I travel a lot for work and when I'm away I tend to flip through pics when I need a 'fix" :laughing:
Thanks for the additional info!
....so I want to start making videos to satify a fix when I can't get up for weeks to play.
In fact, that is the exact reason I started this picture thread.. :laughing:
/ Utility sized tractor picutures #63
VT,
I love this picture of bush hogging! Do you ever have any issues with the rotary cutter being narrower than your tractor? Do you know what the width of your tractor is? I think you said you had it set to it's widest in some older posts. It looks like your probably running a 6' cutter?
Not much. When going round and round a field one wheel runs over grass and bushes that will be cut in the next pass but they have more time to spring back up then if the cutter is right behind the tire. Of course I can't cut that last foot or so next to the fence but that is what a weed whacker/ sting trimmer is for.
You are correct in that is a six foot cutter.
As the tractor is set up now in position 8 with 4.1 inch spacers it is 93 inches wide out to out which lets you trailer it without a wide load setup. The extra stability on my steep ground more then makes up for any hassles trimming the edge.
/ Utility sized tractor picutures #65
Is that one of those (bat wing mowers ) in the right photo??
/ Utility sized tractor picutures #66
Is that your 7040? It looks bigger?
/ Utility sized tractor picutures #68
That's my 2012 7040 traded the 5040 off,still have the other 7040. It has larger front tires and widen the rear out.
Okay, that makes more sense :D
When are you trading your other 7040 in for the T4.75? ;) :D
/ Utility sized tractor picutures #70
Was thinking about a M100gx,priced one the other day. I do like the cab on those 4.75 and that buddy seat,I dunno. Wife said only way would be happy would be to get the M100gx but I would have to wait and get the loader the following year,who knows what may end up in the barn but I do favor the orange. Also been looking the the 100hp Mahindra,my brother just got the 8560IMG-20130213-00165.jpg
That mahindra seems like a great machine! Are those available with hydraulic shuttle shift? I know if I were to buy right now it would be a red T4.75 (i.e. Case 75C for those that don't know), it seems like just about the perfect tractor for my uses.
/ Utility sized tractor picutures #73
New Holland T5070
/ Utility sized tractor picutures #75
Using my 2120 as a "Towtractor", needed to get the 955 back in the shop after a flat front tire. The granddaughter was helping out by steering..... :laughing:
One of the 2120 hooked up to my 907 flail mower and last, hauling out a Soft Maple saw log.
Ed
/ Utility sized tractor picutures #76
This in the only one I have on the computer. 2002 TN75D
Ed,
I'm a big Logrite fan as well, but you brought it to a whole new level! I mean C'mon, buying a tractor to match your cant hook? :laughing:
I really like those older NH's.
/ Utility sized tractor picutures #78
Ed,
Some days you have to do what you have to do.... :D
Ed
/ Utility sized tractor picutures #79
Here is a couple of updated pictures of mine with the tinted windows.
that is a good looking tractor about the perfect size for what i need. i should go look into those for my planned future upgrade.
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Excavator Grapple (A64127)
Excavator Grapple...
