diy power steering
/ diy power steering #1
allen6634
hawesville
600 ford
i have a 600 ford , it doesn't have power steering, i am to cheep, and affraid to buy a power steering conversion kit, so i am thinking that a hydraulic steering set up might be my fix,i have also given a car rack& pinion set up some thought, has any one seenor done some thing like this?
/ diy power steering #2
Check out the thread in this section "home made power steering on my 1963 ford 4000" posted by KYErik last post 5-10-13
/ diy power steering #3
if you have access to an orbital valve and a steering cyl and front pump you can go that way as well.
might be easier to buy one with ps and sell yours. ps became optionaly available in 1954.
ps. many times steering gets difficult due to sector backlash, lack of lube oil in box sump, bad thrust bearings and bad spindle bushings.
small fords have pretty easy steering when it is maintained.
i agree that buying one with p.s. would be easy, but that wouldn't be as much fun. i was happy with the steering till i put a fel on it , i have given the steering system a good look , and it is in amazingly good shape, i like to tinker, so im happy to do this mod, after some thought and looking, i can use a power steering rack.
well now you done went and gone over my head lol,
/ diy power steering #7
power version of the manual box. it has a ring on it for the valving. needs pump and cyls..e tc... IE.. oe style setup.
unit uses a recirculating ball nut and wormshaft....
Toro Timecutter Max (A61166)
Toro Timecutter...
2003 FREIGHTLINER FL70 DAY CAB (A60736)
2003 FREIGHTLINER...
2023 MERCEDES BENZ SPRINTER 3500 4X2 CARGO VAN (A59906)
2023 MERCEDES BENZ...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2015 Freightliner Coronado 122SD T/A Day Cab Truck Tractor (A60352)
2015 Freightliner...
2013 NEW HOLLAND WORKMASTER 35 TRACTOR (A62130)
2013 NEW HOLLAND...
