JD 316 46 inch deck Spindle Question
/ JD 316 46 inch deck Spindle Question #1
OrtisEvans
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
I was disassembling the deck to paint it. I had to cut the bolts holding the spindles on sice JD used carriage bolts that spun when I tried to remove the nuts. The center spindle/hub came off easily. There must be a trick to removing the other two. What is the trick?
Thanks
Ortis
/ JD 316 46 inch deck Spindle Question #2
You could weld a nut to the top and then hold it with a wrench. How to fix the holes? idk
Thanks
Ortis
The answer turned out to be simple: hit it harder! A couple good whacks got the spindles out. As for the carriage bolts: yes, as mfreund suggests, i'll use a hex bolt and nut. No welding required.
2016 Mazda Mazda 6 Sedan (A66738)
2016 Mazda Mazda 6...
10' Sheets of Tin (A64912)
10' Sheets of Tin...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2015 PETERBILT 389 (A67714)
2015 PETERBILT 389...
Container w/Side Door & Window (A64912)
Container w/Side...
24 FOOT ROLL OFF DUMPSTER (A67714)
24 FOOT ROLL OFF...
