New tractor mods
/ New tractor mods #1
dstig1
Super Member
W Wisc
Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
I added a 3rd function to my new tractor. I did it before on my L3130, so I knew what needed to be done, but the new L5240 has a different setup for the hydraulics that made it a bit harder to do. That mostly just meant more expense in the hydraulic lines/fittings. Such is life.
Here are the implement connections. I used 3/8" steel and painted to match, using the same point Kubota does for the factory 3rd function. Also the same basic place it was on my last one. Bulkhead hydraulic fittings attach it to the plate.
I made the brackets to hold the hoses to the existing clamp points on the arm. The brackets come welded on from the factory - I didn't do that. I bent and painted the clamp to fit from 1/8" x 1.25 steel. This shows those and the hose runs. The pic above shows it a bit too.
And buried back in there (above) is the diverter valve. I screwed it to the FEL upright rather than clamping it onto the arm. That was largely due to a suggestion from Brian at Fit Rite Hydraulics (where I got the diverter and joystick switch), plus it was almost necessary to put it there due to the differences I noted above.
That is the hydraulic side.
/ New tractor mods
Here is the electircal/control side.
I tapped into the cigarette outlet in the right hand fender trim area. Here you can see it all torn apart for wiring. I used a relay (black cube) that I stuck to the fender with foam tape to drive the diverter so the joystick microswitch doesn't get burned out quick. Joystick drives the relay which drives the valve. i also added a diode at the diverter to help with the backrush current or whatever it is called when the solenoid opens (not shown).
Here is the master switch (red rocker, just below the yellow PTO knob) for the 3rd function, so you can switch it off if desired.
And Then the FEL joystick itself. There is a problem in that the bushing that comes with the joystick needs to be drilled out to fit, but the rod is 14mm - bigger than 1/2" and finding that drill bit was hard and expensive. Anything above 1/2" gets spendy, especially for one lousy hole. I also decided that the handle would sit too high as -is, so I made a new one out of 1/2" rod, so I could bore the bushing to fit and lower the height. Here that is. Call it my short throw shifter, I guess :) I dropped it about 3" vs the old one (with the rubber knob, held up to compare).
You can see the diverter valve in the background on the last pic
/ New tractor mods
Then what brand new bucket isn't complete without some welding on it? :D
I added 2 chain hooks and a receiver. I used a piec of 1/4" 4x4 angle with one leg cut down to about 1.25" to get a nice flat reinforcement to hold everything in position. This is the heavy duty bucket, so it probably didn't need reinforcing all that much, but it helped these sit better. I am still no better than a so-so weldor, so no close-ups will be shown :D
I also put a radio in, but am waiting for the harness to show up so I can power it up. Probably tomorrow.
That's all. Now it's time to use it to build the new house...
/ New tractor mods
The radio harness came in, so I got that powered up and am rockin' the cab now!!!:cool2:
And the wheel spinner came in from Coleman equipment. Now my life, err, tractor is complete.
That should basically do it for the new tractor. Now time to start using it...
/ New tractor mods #6
Very Nice Work! I'm GREEN .... er ... a....Orange with envy!
Great thinking on the new control stick!
/ New tractor mods #7
Distig 1
Good looking professional work. It's very satisfying to look at a project once its complete, I know that's why I tinker so much.
Did you add a third function diverter or true third function?
If you added true third function, I'm curious did you plumb the 3rd function valve before or after the loader valve ?
I was considering installing a home brew true third function.
My parts list cost ended up being $500.00
The Kubota kit installed was $400.00 more installed.
I went with factory kit. It's a very nice kit lots of preformed hard steel lines.
Again great job on the mods.
/ New tractor mods #8
Here's a quick upgrade I added to my 2008 Mahindra 5525.
Attached a piece of expanded metal screen to the ROPS via hose clamps. Keeps any stuff thrown up by my mowers from whacking me in the back of my head.
/ New tractor mods
Thanks, guys.
Paul - I put in a diverter. I have read complaints here about the Kubota 3rd function that has had some problems with durability, so I stayed away from it. I put a diverter on my previous tractor, so I knew what needed to be done, just needed to get the right parts, at a better price than last time, which I did. I was quite satisfied with how the diverter worked last time around, so I just did it all again. It was a little harder on the L40 than the L30, but nothing too major.
Now just waiting for the Top and Tilt to come in...hopefully soon...
429981 (A61165)
429981 (A61165)
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
2020 DRAGON ESP...
2021 Bobcat T770 (A60462)
2021 Bobcat T770...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
