Chipper Wallenstein BX42 vs BXM42
/ Wallenstein BX42 vs BXM42 #1
Hilltop Hillbilly
Upstate, NY
CaseIH D40
I'm looking to buy a PTO driven Chipper/Shredder, and I'm leaning towards the Wallenstein BXM42 due to positive reviews of the Wallenstein brand here, but I have one final sticking point that's giving me pause.
I know the BX42 (Chipper only) is direct drive, but the BXM42 (Chipper/Shredder) is listed as belt-driven. I'm always leery of how well belts work, especially in a heavy duty (and expensive) machine like this. With the bullet-proof reputation that Wallenstein has, I'd hope this isn't an issue.
Can anyone with a BXM comment on if the belts have ever given them any trouble?
HH
/ Wallenstein BX42 vs BXM42 #2
HH,
I have the 'little brother' to the BXM42- the BXM32. I've only used it a total of about 8-10 hours so far, but haven't experienced any belt slippage problems. When shopping for the unit I too was leaning toward the direct drive of the (in my case) BX 32 ... I have to say that I've been real happy with the BXM, though ...
Frank
/ Wallenstein BX42 vs BXM42 #3
I just bit the bullet, and purchased a BXM42 about an hour ago. I was going to purchase the BX 42 but I have an organic farm and a shredder will also be handy, so for the extra $1,500, I now have both in one machine. My only concern is, I have a JD3320, I hope it's enough tractor!
I recently purchased a new chainsaw and I've been knocking down the cedar like a wildman, so I hope to have lots of chips in the next few weeks!
I'll post pictures when I get it!
Best,
Matt
/ Wallenstein BX42 vs BXM42 #4
I have the same model and love it.
/ Wallenstein BX42 vs BXM42 #6
I have a BXM32 and it's a work horse. No problems with belt slippage. There were a few minor shipping issues (damage to a grease fitting, etc.) that were resolved very quickly. I'm also extremely happy that I went with the chipper/shredder configuration as I've ended up using the shredder more than the chipper.
/ Wallenstein BX42 vs BXM42 #7
I have a BX42. Have used it for over ten years with no problems. Have no experience with a belt drive but can certainly attest to the quality of Wallenstein.
/ Wallenstein BX42 vs BXM42 #8
I have a BX42R (hyd. feed). It's a great machine and does a good job on everything except the "stringy" limbs on our Sitka Spruce trees, which cause frequent plugs in the discharge chute as the small sappy twigs bend rather than cut as they hit the knives. I looked at a BXM also, but was sold on the hyd. feed rollers, which was probably the best $2100 I ever spent. At times, I sure wish it had a shredder on it though.:drool:..Dan.
/ Wallenstein BX42 vs BXM42 #9
I bought a BX42 and it's great, but I wish I had the shredder too at times. I'd get the BXM if you think you'll ever have the need to mulch the small stuff too.
Septemberwheat, my guess is your tractor is more than big enough. Let us know how it works out.
/ Wallenstein BX42 vs BXM42 #10
I got the bxm42 delivered last week. The crate weighed just under a thousand pounds. I have pallet forks for my 3320, and I was SO nervous moving the crate off of the 18 wheeler!!! I'm not that good with the FEL so I went SO slow. When I first lifted the crate I kind of jerked it upward and the back of my tractor lifted a little :shocked: then I tilted the FEL back toward me a little too fast and the crate bounced a little... Now I'm really sweating... Then the driver says 'is your loader a little touchy?' (No pal, i'm about as green as this tractor i'm sitting on!) then he says 'you're clear, back it up!' so I do at about .00000005 mph... I sign for the crate, while i have the crate about 8 or 9 feet off the ground and I forget for a second which way I have to push the joystick to make the FEL tilt forward or backward...
Can you believe this?!
/ Wallenstein BX42 vs BXM42 #11
RutRo
/ Wallenstein BX42 vs BXM42 #12
Good story. I assume you got it all the way down without dropping it. Enjoy the new equipment. Maybe post some photos when you get a chance.
/ Wallenstein BX42 vs BXM42 #13
Yes! I lowered it, very slowly, took the crate apart, put the two pieces in my pick up then attached the unit to my three point hitch. I was so happy to see my hitch pick it right up! I'm putting it together tomorrow morning and hopefully using it next week! I'll take a few photos and post them as soon as I can.
Best,
Matt
/ Wallenstein BX42 vs BXM42 #14
/ Wallenstein BX42 vs BXM42 #15
So I managed to put the chipper together!
Then I used it for about 6 hours. I have to say, it's AWESOME. The chipper works like a champ, but the shredder is what is so amazing! I had some bushy trees and I could grind them down with the chipper to the stems then I'd send them into the shredder. The shredder sucks the stuff in like vacuum cleaner, it's so powerful (it's almost scary). Anyway, I highly recommend it!
Best,
Matt
/ Wallenstein BX42 vs BXM42 #16
No worries there Septemberwheat,
I know exactly how you feel. I haven't had my tractor very long either. It does get better though.
/ Wallenstein BX42 vs BXM42 #17
That's a big piece of equipment but it looks like your tractor is about the right size for it. Nice setup.
/ Wallenstein BX42 vs BXM42 #18
Thanks Gus, yes, I'm pleased with the set up, I must admit, the unit is heavy for my tractor. I certainly won't be picking it up and going full throttle around my property... Hopefully I'll be using it two or three times a year. All the best, Matt
/ Wallenstein BX42 vs BXM42 #20
thanks for the picture, I am leaning towards to bxm 32 due to size, and your picture pretty much confirms it. I have the L3200 so it 's a good reference point. thanks
For size reference, this is the BXM32 on a Kubota B2410.
2023 Global Trailers GT302 30ft. 60YD T/A End Dump Trailer (A61568)
2023 Global...
UNUSED MGY-50KW FUEL HEATER (A62131)
UNUSED MGY-50KW...
2025 Swict 72in. Bucket Skid Steer Attachment (A61567)
2025 Swict 72in...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
