Wallenstein Chipper or Chipper/Shredder
/ Wallenstein Chipper or Chipper/Shredder #21
It's always about the compromise between horsepower-wallet-want! A couple of years ago I approached this same quandry. Unlike some of you, however, I did not envision myself going beyond the BX32 chipper vs the BXM chipper/shredder due my local horsepower limitations (18HP @ PTO). I really liked the direct drive construction of the BX32/42/ ... But, like the OP I could see myself wanting to put more "stuff" through the unit than just branches. I went with the BXM32 from Woodward Crossing (good people to work with!!) and haven't regretted it a single time. It handles the branches I feed it, the small stuff goes through the chipper with ease (yanks the stuff right out of your hand!) and even shreds large amounts of bark that slough off my seasoning firewood. If it ever dries out down here I'll take the digital camera out and get a picture of my pile of chipped material for your reference (my cellphone just doesn't have a good enough camera ...)
Frank
/ Wallenstein Chipper or Chipper/Shredder #22
Furu -
The Kubota dealer in Spokane carries Wallenstein. I list Amber (pop. 2) as where I live because its closer to my place than Cheney. I'm about two miles NE of Amber. Most would have to do as you to find Amber.
/ Wallenstein Chipper or Chipper/Shredder #23
I have a chipper/shredder, but it's not a Wallenstein.
If you're clearing a wooded lot, a dedicated chipper would be the better choice. But for typical residential or small farmette clean up, the chipper/shredder may be a better choice.
Chippers don't do well with small leafy twigs and such...that's where the shredder works best.
It really depends on how much use one expects. I use my chipper/shredder a few times a year for yard clean.
If I had a lot and limited time to clear it out, I'd rent a dedicated full sized chipper. As long as you plan the job (that is, felling and stacking the trees to minimize chipping time), you can chip a lot of stuff in a day...be a tough day though.
/ Wallenstein Chipper or Chipper/Shredder #24
I have a bx42 on a 29 HP tractor. It does fine with small stuff, I often feed pruning trimmings into mine with no issue. The only clogging issues are when you feed extremely sappy material that is green without putting something with wood in it too (starts to jam the chute). For example today I fed a ton of maple branches big and small with full leaves with no issue. On the small stuff just feed a bunch of it at once or mix it with slightly bigger branches and you'll be fine. The best part of the wallenstein is the 4x10 opening, I can muscle just about anything in there and almost never trim branches, even really gnarly ones.
If you feed just plain leaves, garden clippings (i.e. non woody plant material), acorns etc then you probably need the shredder. The only downside to it is that it uses some of the PTO power and is more expensive.
They're great chippers and you can't go wrong either way.
/ Wallenstein Chipper or Chipper/Shredder #25
Sounds like you guys have answered the question I came here for. Picked up a Wallenstein bx42 over the weekend. I was really disappointed that I jammed it three times in less than half an hour. It was jamming when I was putting green pine and cedar through it. I think it is partly because of the sticky sap, and the way the leaves or fronds of the piice spread out and catch on the outfeed. The outfeed looks like it is about 6" across at the start just above the chipping wheel, and then necks down to about 4" at the junction that holds the pivot for the chute. I will lay off the evergreens and run just other stuff through it for a day and see what happens.
What speed am I supposed to run the PTO at? I have 540 or 720. What RPM on the engine is needed? I have a Jinma 354 diesel. I have always used 540 with a brush hog and tiller, so was hesitant to run at 720. Maybe if I crank up the speed it won't jam. I was thinking more power vs more speed.
/ Wallenstein Chipper or Chipper/Shredder #26
You need a shredder! It should run at 540
/ Wallenstein Chipper or Chipper/Shredder #27
I always let freshly downed pine set for about a week before chipping...let that sap dry out a bit. Even then, the needles can be a pain.
As far as RPM...run it per your manual....which I'm sure will be 540 RPM.
/ Wallenstein Chipper or Chipper/Shredder #28
Define "jamming" -- did you break a shear pin, or stall the tractor? Or is the chute "plugging up" with small stuff? If the chute is plugging up, it probably means you are going too heavy on leafy/twiggy stuff. It's important to feed a fairly big limb through periodically to keep the chute clear. I think the manual covers this, and has more tips. I always try to alternate, and if I send a lot of leafy/twiggy stuff through, follow up with a big limb to push everything out. But definitely read the manual, it has a lot of important info.
/ Wallenstein Chipper or Chipper/Shredder #29
I will start off stating that I do not know the Wallenstein chippers so am not familiar with the way they are put together.
Use 540 RPM.
I am not bad mouthing any brand but every machine has or can have issues/limitations that you learn to deal with.
If you have a rotatable chute on the chip exhaust that could be a factor in your jams.
My unit is a large and capable chipper. (look at my avatar)
The chip exhaust is formed by an 8"x8" square tube. It has a rotatable top to the exhaust so that chips may be exhausted in 360 degrees as the operator chooses. I state this as I have found that if I am chipping high mass greenery (lots of leaves and not just coarse woody stems) that I can jam the 8 inch square exhaust with vegetative green debris if the adjustable rotating top exhaust is set 45 degrees from the bottom tube which restricts the passage way. If I am chipping large amounts of greenery then I ensure that the upper exhaust tube is set to match the lower exhaust tube so that there is no air flow restriction. If I am doing just coarse woody stems then I never bother about it as only greenery seems to cause it.
If you have an adjustable exhaust, look and see if you could be partially blocking the exhaust path by accident. Mine never jams if I am chipping wood no matter how big but if I get a lot of leaves and fronds, with the tube rotated to restrict, then a jam will occasionally occur.
If you do not have an adjustable exhaust then forget I said all of the above.
/ Wallenstein Chipper or Chipper/Shredder #30
You need 540 RPM for PTO speed. Try spraying your chute with WD-40, that will help to remove the sap that is there and help for a short while with new stuff. As stated feed larger woody material through with any small branches or leaves, the mass of the wood will blow out anything that's getting stuck in the chute. The chute clogs because the light leaves don't have enough mass to push through and tend to come out in clumps. You can feed slowly and that will help too. I personally like to let stuff dry a couple of days and then there's no issue, or I put the butt end of the next branch in with the top of the previous one to have plenty of wood chips mixed with the leaves and slow my feed rate a tad and that works.
/ Wallenstein Chipper or Chipper/Shredder #31
On the BX42 they are rated to 1000 RPM's per Wallenstein so you can run it faster which helps with the light stuff. Also adding some thicker wood as others have said will also keep the chute clear.
/ Wallenstein Chipper or Chipper/Shredder #32
The BX42 is a great chipper but like I've said on here before, it's not really meant for twigs and other lightweight stuff that a chipper/shredder is designed for. I too have had my chute plug because I put too much small stuff through in a row. It wants to eat larger branches and spit out chips to clear the chute and you have to alternate between the larger stuff and the smaller stuff to keep the chute clear. I like the idea of WD-40 in the chute. I'll try that.
I would have bought the BXM42 but it was just too big for my taste. I think my tractor would have handled it ok with 31HP but I like the maneuverability of the chipper and the direct drive keeps it simple. It really has been a reliable piece of equipment. I hope it works out for you.
/ Wallenstein Chipper or Chipper/Shredder #33
It is not only the small stuff but how green it is. Sap makes things sticky. Instead of WD-40, you can spray down the chute with diesel. Even better, do what I do, 1 part old motor oil, 2 or 3 parts diesel. Either a pump sprayer or an old paint brush.
/ Wallenstein Chipper or Chipper/Shredder #34
shoot it with MO-DECK
/ Wallenstein Chipper or Chipper/Shredder #35
Thanks, I'll try all these and see if it helps. I want it for a chipper for sure, I will break up the tops more and not try and jam all in at once. Thought about feeding them "backwards" as well, putting the bushy leaves and all in first and following up with the thicker trunks. Seems like it would pull in a lot better feeding the larger pieces in first though. This still has the new green paint in the shoot, so maybe a good dose of oil or lube will help stuff fly through.
/ Wallenstein Chipper or Chipper/Shredder #36
I am also in the market, have the L3200 and trying to go bxm 32 or bxm 42? Have about 5 acres with potential for another 60. Chipper/shredder? That is the question.
/ Wallenstein Chipper or Chipper/Shredder #37
Just like the OP you will be wishing you had a shredder.
/ Wallenstein Chipper or Chipper/Shredder #38
that was my thinking as well, lots of small trees to clear up, and probably I should be going for the 42 for the bigger shoot size.
/ Wallenstein Chipper or Chipper/Shredder #40
I ordered the bxm32 yesterday from Woodward crossings it should be at the lumber yard Fri. The people there were great the price was the best I could find and will have it for the weekend. I will report back how it works.
2007 IC Corporation PB105 School Bus (A64194)
2007 IC...
2016 CATERPILLAR CT660 SBA 6X4 DUMP TRUCK (A63276)
2016 CATERPILLAR...
2021 CATERPILLAR 302.7D CR EXCAVATOR (A65053)
2021 CATERPILLAR...
MASSEY FERGUSON 28 BLADE DISC HARROW (A64278)
MASSEY FERGUSON 28...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
