2010 JD 2320 electrical fire-disaster
   / 2010 JD 2320 electrical fire-disaster #1
Phil D
Member
Hi all-I purchased my 2320 in April 2010. At 195 hours last week I just did oil, transmission/hydro fluid, all filters and full lube on machine, bucket and 62" Mower. Mowed my lawn once-2 hrs and just mowed the neighbors field last evening-2 hrs. On the way home via my back trails as I got out into my field I smelled a funny chemical burning smell. I looked down and could see a glow behind the emergency brake latch and realized there was an electrical fire. I was still 300 yards from home so tried to drive there. Got to 150 yards from the house and the machine shut down. I sprinted and got two small extinguishers, raced back up the hill, popped the hood and tried to extinguish the fire which was concentrated in the electrical circuitry below the steering wheel. Very difficult to direct the extinguisher in there. Neither extinguisher was able to fully suppress the fire which was very white hot. It quickly spread with all that plastic and consumed the machine in a minute. I then raced and filled 5 gallon buckets and made 20 trips and finally, 40 minutes later, put the fire out. I live in a rural area with volunteer fire dept, long narrow driveway, very difficult spot to get to. I've been an EMT. I know response times here. I didn't bother calling the FD. I am sick about this. Insurance company says there not sure I'm covered as it was not listed under personal property. I called the dealer and haven't heard back. I have owned tractors for 25 years. I still have my trusty '63 Farmall 140. We have run a commercial maple syrup operation for 20 years, we have extensive gardens, cut and split lots of firewood, we know our machinery.
I have seen gas fires, grass-caused fires and electrical fires. This was 100% an electrical fire emanating from the circuitry below the steering wheel.
I am girding myself for a major battle. I have seen in some other forums where JD takes fires fairly seriously. Does anyone have any experience with this type of situation?
Many thanks-Phil D
   / 2010 JD 2320 electrical fire-disaster #2
Phil, I am sorry to hear of this bad experience you had! I could not imagine seeing that. I have never heard of a fire like that on any of the JD machines, sorry.
Thanks Kenny. I sobbed for one second but was dead-set on battling the fire. Just a horrible feeling.
   / 2010 JD 2320 electrical fire-disaster #4
I haven't heard of any electrical problems on any of the compact series tractors. The best thing to do when an electrical fire starts is to get the battery disconnected as quickly as possible. I know that isn't always posible, but even if you can cut the cable going to the starter, it will remove the source of ignition. Once a flame actually starts, it will continue to burn, but at least the electrcal heat will be gone. That is one reason I always like to have at bare minimum, a pair of pliers and wire dykes/side cutters handy in any vehicle or tractor. Fast action getting the battery unhooked can avoid major damage. John Deere does take fires very seriously. Make sure your dealer reports it to the fire safety hotline. It is a dealer only hotline so I can't post the number here. There should however be a customer support number in your owner's manual. I recommend you contact them. I guarantee the dealer will get a call from them and will be sure the dealer takes action.
I really appreciate your reply. I often have a small tool box on board but had pulled it off during my service routine. After I raced back and forth to get fire extinguishers and tried to suppress the fire-unsuccessfully-I then grabbed a heavy pair of linesman's pliers but the burning plastic made it too hot to get near the battery cables. After I brought my Nth 5 gal. bucket of water and doused the machine I was finally able to cut the negative lead. The battery was still juicing the frame-it was a real live nightmare. Big thanks for your input. Monday is going to be an endless series of phone calls.
   / 2010 JD 2320 electrical fire-disaster #6
Sorry to hear of your mishap. Be glad it burnt where it did and not later on after you parked it in a shed. JD had a real problem back in the seventies with their ag tractors that would spontaneously com-bust in the cab area. It was always electrical and usually started after it was parked.
   / 2010 JD 2320 electrical fire-disaster #7
Really sorry to hear this. I can just imagine the gut feeling you had while trying to extinguish the fire. Do you have pics. of the damage?
   / 2010 JD 2320 electrical fire-disaster #8
Phil
That is terrible! Hope your homeowner's insurance comes through you would think they would pick up a part of the repair/replacement cost at least. I carry a small fire extinguisher strapped to the ROPS but no way it could have controlled what you described. I will definitely add something to cut the cables. Never even thought of that before. Please keep us posted!
Ed
Shamus
Phil was/is an EMT. The other fires were probably on responses he was on.
Ed
Bingo.
Thanks Ed.
In 25 years we've had one tiny gas fire on a farmall. Quickly extinguished.
Shamus-I don't appreciate your insinuation that it was negligence. We maintain our equipment impeccably. Electrical fires on a machine with less than 200 hours would be hard pressed to fall into the "negligence" category but I guess with your "60 years of farming" you would know that. Maybe you can't read very well. I said "I've seen" the other types of fires. And as the other poster pointed out...many of them on Emergency calls but some when I worked for an oil-exploration company in Wyoming. The point, which the other posters have all understood, is there is a distinct difference in fire types. Gas, grass, diesel, plastic and other materials burn very differently. So, for all of your 60 years of farming experience it sounds like you really haven't seen much. I'm not sure I will even address your comment about firing Hispanic workers but I guess the fact that you hire them in the first place says either your labor pool is too small or you're too cheap to pay a better wage to non-Hispanics. I have travelled many parts of the world including extensively in Central America (look it up if you're not sure where it is) and can assure you that your narrow-minded racist comment is just that. Hispanic people are just like everyone-some good ones, some bad ones and, unfortunately, some ignorant ones.
Now, back to our regularly scheduled programming. I spoke with my insurance agent this evening-ALL IS WELL. I'M FULLY COVERED. WHEEEEEWWWWWWWW......
I can post pictures but it has been like a loss in the family. I covered it with a tarp and haven't wanted to look at it. But I think I'll get some pix on Monday for posterity.
The gut feeling after I discharged the 2nd extinguisher was real helplessness and despair-150 yard sprints up a hill with 5 gallon buckets on full adrenaline was all I could do.
I told a friend of mine about it today and he said " You're a real Yankee-just wouldn't let it burn, would you?" And I replied "No. I was going to get that fire out eventually. I had to."
I must admit-I'm 49, 5'11-185 lbs, run a couple of miles 3-4 times a week, cut and split 10 cords a year, big gardens, 30 fruit trees...but in real life I'm a commercial photographer and
spend a lot of time sitting at my computer editing my work. My legs and arms were really, really sore this morning.
Any new features on the 2320 since 2010 that I might be looking for?
WHAT I REALLY LOVE ABOUT THIS FORUM AND THE KIND-HEARTED POSTERS IS THE SUPPORT, INFO AND THE EXCHANGING OF INFORMATION.
If there is anything in my experience that can help others then it was not a total loss.
I will definitely carry 2 extinguishers and never leave the garage without the tool box. Just the heavy Linesman pliers might have helped at the outbreak.
The reality is: unless the machine caught fire near home there's not a lot one can do-couple of heavier extinguishers, tools and hope!
Thanks,
Phil
Big thanks to all and we'll keep you posted.
   / 2010 JD 2320 electrical fire-disaster #10
Phil, great news on the insurance company! Now, good luck finding a 23, 25, or 2720 since they are technically discontinued for the model year '13
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
John Deere A Tractor (A50514)
John Deere A...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
John 4 x 4 cart (A50323)
John 4 x 4 cart...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
