dewson
Hi recently purchased a siromer 204s tph not working steering ok any body got any ideas regards :confused2:
When you try and lift the 3PH, does the engine sound any different, like it is being placed under load? This would indicate the system is building hydraulic pressure. This means the control valve is trying to send fluid somewhere which is causing pressure to build which is good. If the engine dosn't change sound, it could be that the valve has an internal problem and is not sending fluid where it belongs. Or the safety relief in the 3PH valve is stuck open keeping it from building any pressure. Or the seal on the 3PH piston is blown and the fluid is just flowing past the piston instead of lifting it.
If the engine DOES bog down/change sound when you try and lift the 3PH, Does the tractor have a 3PH speed regulating valve on it, usually a knob(looks like a round water faucet handle) down in front of the seat? It is used to keep heavy 3PH loads from slamming to the ground. IF that is screwed all the way in, it could be preventing any fluid from reaching the 3PH cylinder and lifting the hitch. Or if the speed reg valve is open, it could be the internal linkage in the lift is mechanically jammed.
Good Luck
Hi yes the diverter valve has been checked piston slides without any problems, slackened two banjos on top oil leaks out slackened banjo on the rear only a few drips , oil is returning to the tank lift unit through the return pipe, pump seems to be pushing out a good pressure. tractor has 96 hours only and has sat idle for some time they purchased it new and had given up hope, somebody has looked at it previously and given up, only wish I had a diagram for the diverter valve in case its assembled wrongly or something missing that I am unaware of, thanks again for your invaluable help as I am lost for answers regards DewsonWhen you say valve has been checked, which valve are you refering to? Have you disassembled the diverter valve and checked that it's piston is sliding freely?
Do you have the speed regulator valve that Ron mentioned in his first post? If so, try screwing it all the way down then see if there is any change in engine sound when engaging 3ph.
RonJ
Well IT could be the diverter not returning to main position to feed 3PH, or the rotary vane pump/steering assembly is leaking past, allowing flow out of the diverter which keeps it diverted to the priority/steering port.
One way to break this tie, short of swapping one out, might be to plug that priority port, and deny flow to steering the same way the steering box should when you are not turning the wheel. If working properly this should make the diverter valve flow fluid to the 3PH. You could plug the port to the steering fairly easilly with a metric bolt put in place of the hollow banjo bolt. Doing this would have one of two outcomes
1. The diverter will function as designed and send fluid to the 3PH, indicating the steering vane pump/valve is the issue.
2. The diverter valve will stay stuck in divert. Since this port is now blocked for testing, the pressure will build till it exceeds the relief pressure in the diverter and fluid will flow out that 4th diverter port . The 3PH will continue not to function. You may hear the added load on the engine, but it should only build as much pressure as the system does when you turn the steering out to one steering limit or the other. On mine it builds about 500 PSI. To confirm that the diverter relief function is working properly before you block the port, you can start the engine and while idling, turn the steering all the way to a stop and see how the engine responds. You should hear it load down a bit when the steering reaches an end stop. IF it stalls the engine at idle, it may not be relieving properly, and may not be advisable to do the blocked diverter port test as without a relief, would completely dead head the pump with a malfunctioning diverter valve.
Fluid should only be able to get to the ram when you turn the wheel. If fluid was headed to the ram it would be pushing the wheels left or right. If the ram was leaking past, the wheels would not turn or turn sluggishly when you turned the wheel.
In thinking about this some more, I went out and pulled the output line on my steering valve/rotary vane pump to check, and surprisingly(well not really when I think about it) there is fluid flowing out of it whenever the engine is running. So some assumptions I was making earlier are incorrect. And if I had thought about it a little more, it probably would have come to me then. You need flow to control flow, so there is always some flow thru the steering valve. It is when the steering is operated, that more flow is demanded from the system, and the diverter shifts more flow to the steering, denying flow to the 3PH in the process. SO either the diverter is faulty, or the pilot flow thru the steering is excessive, causing the diverter to remain diverted to meet this demand. After this revelation, I am thinking the only way to troubleshoot this further is to swap out a part. My first choice would be the diverter as it is less expensive and easier to access and swap. Here is some additional info on the diverter from Johns Jinma website.
DiverterValve
