2150 w loader and mower
/ 2150 w loader and mower #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
looking at a 2150 for the church. has laoder and mower.
looks very clean. seller says it is 50hp and 1520 hours, 86 model ( 2wd ).
any idea on value.. or any other info to help us decide?
i'm not a jd guy.. though have done some work on and with a 2240 etc...
/ 2150 w loader and mower #2
They are 45PTO HP. Made 1983-1986. TSS transmission std. Top Shaft Synchronized, so shifting could be made "on the go" in each gear range.
What model loader? 1520 hours is very low for a 28 year old tractor. Not sure of value.
/ 2150 w loader and mower #3
50 series are good tractors. Does it have collar shift ot TSS trans? I agree 1520 hrs is low maybe 11520 hrs. Does drawbar,3 pt balls,steering linkage or clutch pedal exhibit much wear?
havn't seen it yet. looking for something newer...OR ford.. hopefully. :)
/ 2150 w loader and mower #5
If it is a 86 then it is a late model. I own a 2155 which for the most part is the same tractor. Mine is a 1987 model. I do have a brochure for the 55 series and it says there where a bunch of updates to my tractor but does not list them so I am not sure what the changes where between these two series of tractors. I have seen 2150 model tractors for sale anywhere from 8,000 in rough condition up to 13,000 with loader. Most seem to be around the $10,000 range. I know the tractors alone without loader I have not seen advertised for any less than $7,000. I have heard the 50 series where just about as good as the 55 series. They seem to be a well balanced tractor for the size and weight. The engines in them are very reliable. Does it have the independent or live pto? Easy way to tell is if it is independent it will have a leaver with a yellow handle you pull up about mid ways on left side of dash.
(INOP) CATERPILLAR AP500E ASPHALT PAVER 2 STATION (A62130)
(INOP) CATERPILLAR...
DYNAPAC CA250D SMOOTH DRUM ROLLER (A62129)
DYNAPAC CA250D...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
Ford BS454C Tractor with Box Blade and Sweeper Attachment (A61567)
Ford BS454C...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
