Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please
   / Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please
Re: Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please
Ok, so I'm back to considering Hay again! :D I'm actually going to a friend's grandpa's farm later this week to bend his ear on the matter - sounds like he's pretty excited to take on a new pupil in his old age.
Ed mentioned "Red Clover" before and commented on the fact that I have grass already existing below the weeds in those photos. As soon as the ground firms up, I plan to mow down everything in that field. If I spread the Red Clover, should I expect it to grow to anything substantial this year? Is that something worthy of harvesting compared to other variety's of hay? Is that just a temporary "stop-gap" that will transition me to planting some other strain there next year? Or, is Red Clover a good thing to stick with?
Also, that above field is around 3+ acres (which will turn to 4+ by the end of the year as I take down another tree line)... my OTHER field is also 3 open acres of grass. Not sure what kind, probably fescue or something similar. I typically just mow it weekly. What do I do with that field? Do I let it grow as is and treat it as hay? Or, do I plant clover there as well? The only weeds that seem to pop up in that field are dandelions (mostly) and a few of the small picker things.
Thanks again for all the advice. I'm now running 35 PTO HP, so I should be able to handle a small baler now for this operation if I decide to do it.
   / Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please #83
So how is the decision going now? This has been real learning experience.
Well, I decided against hay. So far this year I got about an acre of jack-o-lantern pumpkins (Connecticut field) in the ground. Still working on other stuff, but have so much to do it's been tough to keep up.
   / Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please #85
We raised pumpkins a few years, not that many though. How are you planning to sell them?
Still working on that part LOL... who knows if any of them will actually grow.
Actually, I have a few small retail outlets that may split profits with me to sell them. Won't make me rich, but might make a few bucks.
   / Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please #87
:thumbsup:
   / Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please #88
I went with trying to make a go with hay on 5 acre plot, this learning curve will be a corkscrew.
Best of luck to you man, I hope that it works out well. For me, I decided that the upfront cost, even with buying all used equipment would be too costly for this small of an operation. A family friend does about 160 acres of hay and does pretty well... But he also steered me away from it on my property because I have such a few acres to do it with.
I'm hoping to get some fruit trees and some berries planted before fall, along with A to be determined amount of Christmas trees.
I'm excited to see what happens with the pumpkins that I planted. I planted the seed with a few different methods to see which one would work best for me. Hopefully I get a reasonable result
Okay... here they are! :D
So far have 26 pumpkin seedlings sprouting up (out of the 300 or so seeds I put in the ground)... every day I have a few more coming. I'm not expecting too much, but this is a fun test to see what'll happen.:dance1:
2012 UTILITY TRAILER MANUFACTURER FLATBED (CRACKED FRAME) (A58214)
2012 UTILITY...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
MARATHON 20KW GENERATOR (A58216)
MARATHON 20KW...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
60 GALLON METAL OIL DRUM (A52708)
60 GALLON METAL...
