Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please
   / Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please
Re: Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please
Ok, so I'm back to considering Hay again! :D I'm actually going to a friend's grandpa's farm later this week to bend his ear on the matter - sounds like he's pretty excited to take on a new pupil in his old age.
Ed mentioned "Red Clover" before and commented on the fact that I have grass already existing below the weeds in those photos. As soon as the ground firms up, I plan to mow down everything in that field. If I spread the Red Clover, should I expect it to grow to anything substantial this year? Is that something worthy of harvesting compared to other variety's of hay? Is that just a temporary "stop-gap" that will transition me to planting some other strain there next year? Or, is Red Clover a good thing to stick with?
Also, that above field is around 3+ acres (which will turn to 4+ by the end of the year as I take down another tree line)... my OTHER field is also 3 open acres of grass. Not sure what kind, probably fescue or something similar. I typically just mow it weekly. What do I do with that field? Do I let it grow as is and treat it as hay? Or, do I plant clover there as well? The only weeds that seem to pop up in that field are dandelions (mostly) and a few of the small picker things.
Thanks again for all the advice. I'm now running 35 PTO HP, so I should be able to handle a small baler now for this operation if I decide to do it.
   / Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please #83
So how is the decision going now? This has been real learning experience.
Well, I decided against hay. So far this year I got about an acre of jack-o-lantern pumpkins (Connecticut field) in the ground. Still working on other stuff, but have so much to do it's been tough to keep up.
   / Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please #85
We raised pumpkins a few years, not that many though. How are you planning to sell them?
Still working on that part LOL... who knows if any of them will actually grow.
Actually, I have a few small retail outlets that may split profits with me to sell them. Won't make me rich, but might make a few bucks.
   / Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please #87
:thumbsup:
   / Looking to start growing & harvesting Hay - with a Compact Tractor. Advice please #88
I went with trying to make a go with hay on 5 acre plot, this learning curve will be a corkscrew.
Best of luck to you man, I hope that it works out well. For me, I decided that the upfront cost, even with buying all used equipment would be too costly for this small of an operation. A family friend does about 160 acres of hay and does pretty well... But he also steered me away from it on my property because I have such a few acres to do it with.
I'm hoping to get some fruit trees and some berries planted before fall, along with A to be determined amount of Christmas trees.
I'm excited to see what happens with the pumpkins that I planted. I planted the seed with a few different methods to see which one would work best for me. Hopefully I get a reasonable result
Okay... here they are! :D
So far have 26 pumpkin seedlings sprouting up (out of the 300 or so seeds I put in the ground)... every day I have a few more coming. I'm not expecting too much, but this is a fun test to see what'll happen.:dance1:
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
NEW Landhonor LHR=EPC40 Plasma Cutter (A59000)
NEW Landhonor...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
2014 Peterbilt 388 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2014 Peterbilt 388...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
