L4760 vs L4240
/ L4760 vs L4240 #1
sxs191
I have been to two dealers that each have the L4760 on their lot. I looked up the specs on the L4760 and the loader is showing to have 100 lbs less lift at the pivot pins and 100 lbs less lift at 500 mm forward and 1000 lbs less break force than the 4240. I thought the new L60 models were supposed to have a stronger loader, not weaker. I better get my hands on the L4240 before they are all gone.
/ L4760 vs L4240 #2
That is what I did. No regrets!!!! Got 47 hours on my 4240. It's a HOSS!
/ L4760 vs L4240 #3
I seriously doubt you will notice a difference between the two.
/ L4760 vs L4240 #4
Maybe they are being more realistic on their specs. My L5740 checks right on relief pressure but will not lift what is claimed in their specs. We get grain in totes, a bag 4x4 x about 4 high. That puts the CG of the bag pretty close to 500 mm in front of the pins which is a load point in the spec and it falls a couple hundred pounds short.
/ L4760 vs L4240 #5
Be interesting to know the price difference between them....
/ L4760 vs L4240 #6
its because the loaders on the GL60's are coming with standard quick couplers, and they where optional on the GL40's. The couplers add weight and move out the pivot points so there is a small spec decrease. Equally equipped, both have the same capacity.
/ L4760 vs L4240
That makes sense on the lift capacity but a 1000 lbs difference in the breakforce?
I really like the location of the new gas cap but I wasn't too fond of the new front loader hydraulic valve connection points located on the outside of the loader arms.
/ L4760 vs L4240 #8
Yup. That's the impact of moving the bucket out an extra 3". Small changes to loader geometry can make huge differences.
IMO... manufacturers should list their loader specs with and without the coupler so people can make educated choices, sadly many don't want you to be educated.. they just want a big number for their brochure.
/ L4760 vs L4240 #9
How much do your grain totes weigh?
/ L4760 vs L4240 #10
Your grain tote will weigh in close to 2500 lb. That is well beyond what the loader is rated at.
/ L4760 vs L4240 #11
Our totes are all loaded to 2,000 pounds plus or minus 25 - that is for the wheat totes. They don't fill them completely for handling purposes. I do have my way of moving them - work it to tilt back as far as possible bringing the CG closer to the pins, but the main thing is to get the JD 6320 which has no problem lifting if it is available. Tomorrow we will have a M135GX but still it would be nice if he L5740 had a little more oomph because it is so more maneuverable.
/ L4760 vs L4240 #12
I bumped my relief pressure 200# which made some difference. Mine will lift to the point where it still picks the back wheels off and that is with 1400# on the 3pt and another 750# of cast wheel weights.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
2023 CATERPILLAR 299D3 SKID STEER (A65056)
2023 CATERPILLAR...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
2010 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2010 ALLMAND...
2007 OK TRUCK & TRAILER PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
2007 OK TRUCK &...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
