ITS HERE!!!!.....3320 cab
/ ITS HERE!!!!.....3320 cab #1
mcgill72143
Arkansas
2013 John Deere 3320 Cab
I went by the dealers lot today and seen it setting there all shiny.....I called my dealer and he said it came in with the wrong R4 tires because John Deere said they are behind on making the R4's that I wanted and it would be a month wait to get the correct ones.....so I can either settle for the ones that are on it or he can order them and I wait a month..........I think this sounds like bs and it sounds more like the dealer ordered the wrong tires from the start.. ...What should I do guys....?....:confused3:
/ ITS HERE!!!!.....3320 cab #2
Yes, sounds like typical dealer BS. Tell him you will take the tractor as is if next month he will install the tires you ordered. If he doesn't agree then tell him no deal.
I really cant tell what the difference is in the two R4's anyway......one has a curved tread and the other type (what my 2320 had) has a more block tread.....
/ ITS HERE!!!!.....3320 cab #4
well in that case I would just settle with the tires it arrived with then. that's just me though.
thas what im thinking Mike.....I'll get a better look at it Monday...
/ ITS HERE!!!!.....3320 cab #6
My tractor has the R4 block type tread and they do the job. Dunno if the curved type is better or not. :confused3:
/ ITS HERE!!!!.....3320 cab #7
Don't know which ones you actually ordered, but there is a size difference, a price difference and a rating difference. If you got the more expensive, by mistake, it might be worth accepting. Others have posted they think the larger tires make the tractor look better.
25x8.50-14 6PR Front R4 Ind 2 Pos.
15-19.5 6PR Rear R4 Ind. 2 Pos. $230.00
27x8.5-15 6PR Front R4 Ind. 2 Pos.
43x16-20 4PR Rear R4 Ind. 2 Pos. $410.00
27x8.5-15 6PR Front R4 Ind. 2 Pos. ...........this is what it came in with....might be worth leaving on there ......
/ ITS HERE!!!!.....3320 cab #9
Especially if you only paid for the $230 version.
/ ITS HERE!!!!.....3320 cab #10
Tell the dealer that you will except the tractor for $100 off for the wrong tires.... you might get it, worth a try.
Im just hoping the bigger tires don't push it over my garage door height....I only have 93"1/2 to the top seal......
heres some pics at the dealers lot....
/ ITS HERE!!!!.....3320 cab #13
For the small difference in price, I would be more concerned about the performance. You may have gotten more that what was quoted, but you will have those tires for many years, and how the tractor engages the ground is very important. I would talk to the dealer about performance. It could be those tires may even be better for your uses. Good luck. Sweet tractor!
/ ITS HERE!!!!.....3320 cab #14
if a dealer actually knows anything about the products that they are selling, I guarantee that tire tread and performance is not one of them. A dealer isn't going to steer them another direction especially if its already setup. So seriously dude that's a complete waste of time and like talking to a wall. The only person that could accurately answer that question is someone that has owned the exact tire design and then switched to another for comparison on the same tractor. Im sure he will be just fine.
/ ITS HERE!!!!.....3320 cab #15
Hiya,
I believe the tallest tire on cab versions is the R3 turf. The manual ( OMLVU17926_J7 ) lists:
Height From Ground (Tractor with Cab, R3 tires)
To Top of Cab 2.3 m (89.4 in.)
Tom
Thanks guys.....I went by the lot because the dealer said he went out and measured the cab clearance and he got 89"......I measured while I was there and got 90"......looks like it will fit but I just need to go slow the first time in....:laughing:
Stopped by the dealer today and he said John deere called and said they forgot to ship the manual lift without the $1200 auto connect..... I didn't order the auto connect because I was going to add it later and just use the manual lift for now..... Anyway john deere didn't ship the lift parts so they went ahead and shipped the autoconnect for free...... Sweeeeet......
/ ITS HERE!!!!.....3320 cab #18
Those are the exact size my Kioti has on it.
/ ITS HERE!!!!.....3320 cab #19
Gotta be happy with that mate :)
:cool2: The dealer said as soon as the auto connect hardware comes in then they will install the mid pto, pto lever kit, rear wiper, rear work lights, JD cd player and the belly mower by the next day. He's saying I should take delivery the middle of this coming week.
