ITS HERE!!!!.....3320 cab
/ ITS HERE!!!!.....3320 cab #1
mcgill72143
Arkansas
2013 John Deere 3320 Cab
I went by the dealers lot today and seen it setting there all shiny.....I called my dealer and he said it came in with the wrong R4 tires because John Deere said they are behind on making the R4's that I wanted and it would be a month wait to get the correct ones.....so I can either settle for the ones that are on it or he can order them and I wait a month..........I think this sounds like bs and it sounds more like the dealer ordered the wrong tires from the start.. ...What should I do guys....?....:confused3:
/ ITS HERE!!!!.....3320 cab #2
Yes, sounds like typical dealer BS. Tell him you will take the tractor as is if next month he will install the tires you ordered. If he doesn't agree then tell him no deal.
I really cant tell what the difference is in the two R4's anyway......one has a curved tread and the other type (what my 2320 had) has a more block tread.....
/ ITS HERE!!!!.....3320 cab #4
well in that case I would just settle with the tires it arrived with then. that's just me though.
thas what im thinking Mike.....I'll get a better look at it Monday...
/ ITS HERE!!!!.....3320 cab #6
My tractor has the R4 block type tread and they do the job. Dunno if the curved type is better or not. :confused3:
/ ITS HERE!!!!.....3320 cab #7
Don't know which ones you actually ordered, but there is a size difference, a price difference and a rating difference. If you got the more expensive, by mistake, it might be worth accepting. Others have posted they think the larger tires make the tractor look better.
25x8.50-14 6PR Front R4 Ind 2 Pos.
15-19.5 6PR Rear R4 Ind. 2 Pos. $230.00
27x8.5-15 6PR Front R4 Ind. 2 Pos.
43x16-20 4PR Rear R4 Ind. 2 Pos. $410.00
27x8.5-15 6PR Front R4 Ind. 2 Pos. ...........this is what it came in with....might be worth leaving on there ......
/ ITS HERE!!!!.....3320 cab #9
Especially if you only paid for the $230 version.
/ ITS HERE!!!!.....3320 cab #10
Tell the dealer that you will except the tractor for $100 off for the wrong tires.... you might get it, worth a try.
2010 Deere 318D (A60462)
2010 Deere 318D...
Giyi KH72 QA 72" 4-in-1 Bucket (A60463)
Giyi KH72 QA 72"...
Mini drum mulcher (A61567)
Mini drum mulcher...
2024 Case IH Farmall 75A (A60462)
2024 Case IH...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2011 TROXELL...
Adams 16T Tender Body (A61307)
Adams 16T Tender...
