diff lock broke?
/ diff lock broke? #1
HK45
Gold Member
Bethlehem, Pa
Kioti nx6010 loader backhoe
On my ct450 Its hard to go around turns and when I drive into a pile of stone I see both back wheels driving at the same time. Is my diff lock broke or is that normal?
/ diff lock broke? #2
Its stuck in the engaged condition. Look for the linkage from the engage pedal and lubricate all pivots. Back up while turning the wheels back and forth afew times to aid in taking tension off the lock gearing. This should allow the spring driven disengagement mechanism to work. The engagement pedal should pop back up.
larry
/ diff lock broke? #3
larry
Sounds like it is for sure engaged and working but it is not disengaging freely properly. I would get it jacked up and lubricate all of the linkage real good and try to get it to release by lightly rocking the tire and lightly pulling up on diff pedal. Be sure to really lubricate it good where it goes into the rear housing. With this engaged and trying to turn you can damage it. It is designed to work in soft conditions and release on its own once traction is established. Some brands recommend to also hit brakes to release it if it does not release on its own.
2021 International HX620 Quint Dump (A62613)
2021 International...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
2022 EZ-GO ELITE...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
