Broken axle shaft!
/ Broken axle shaft! #1
kentuckydiesel
Was doing some general gravel work the other day when my front right wheel locked up.
Tore it down to find a broken yolk on the outer shaft, along with the ears broken out of the double cardian type center connector between the inner and outer shafts. Not too happy.
Check with John Deere...they want nearly $800-$1000 for the axle parts I need. Now I'm pissed.
Have a call into the Carraro axle parts dealer in Ohio to see if they can do any better.
Anyone else ever deal with this? Anyone ever find a better replacement option? Know if any other manufacturers use the same model Carraro front axle as my 5200 has? (#126554)
I will file this thing out of a block of metal before I give JD $1000 for parts!!! (or just put a new yolk on the old shaft) ;)
Thanks,
Phillip
/ Broken axle shaft! #2
Check with a drive line shop. I recently bent the drive shaft that powers the front tires. Was able to save several hundred letting them rebuild my shaft.
Yea, that'll fit...but $400 for a used axle shaft is still pretty steep. I've just been running the tractor in 2wd for the time being. Think I'll try and rebuild this shaft and see how that works out.
-Phillip
/ Broken axle shaft! #5
What went south that caused the problem? Be good to know for the rest of us.
/ Broken axle shaft! #6
Was wondering how many hours you have on the tractor? Also, what were you doing when it broke?
You might try a tractor salvage yard, however that is a moving part and chances are from a high time machine. Sometimes there are units that get caught up in a hay baler fire and the front end is still perfectly fine.
/ Broken axle shaft! #7
Did part #5 break at the yoke? Or #4?
/ Broken axle shaft! #8
Looks like the shaft is $668 while #4 is about $164
Maybe you could get the shaft repaired at a driveline/ driveshaft shop?
/ Broken axle shaft! #9
I have a Mahindra 7520 that had a similar problem ... 1,3,&4 were twisted out under high load conditions. The reason, I think, is that the tractor hydrostatic steering often cannot control wheel direction in high load differential traction conditions and the wheels will be steered sideways in a hard push regardless of steering wheel input. I replaced the whole shown assembly end to end for around $500. Glad it wasnt $1000 as in OP case! I cant image being successful fixing the damaged parts.
larry
/ Broken axle shaft! #10
larry
That makes sense Larry. How or where did you find the stuff to fix it so cheap.
/ Broken axle shaft! #11
I got it thru LaWalls Tractor. Its for a Mahindra tho ... looks identical, but probably not. :confused3:
larry
The ears for on 4 and 5 broke. I am pretty sure the u-joint went out and took the ears with it. No sign of any u-joint caps in there. Tractor has about 1500hrs.
-Phillip
larry
I run a big steel fabrication shop so it's not outside the realm of possibility for me. Heck, one time I made a conversion u-joint for the rear driveshaft of my 350-400hp diesel F350 in a barn using parts from two u-joints, some hot rolled steel strap, a stick welder, an angle grinder, and a little bit of time. That **** thing held up for 15,000mi. (I just had to see how long it would last) :)
-Phillip
/ Broken axle shaft! #14
I would call a driveline shop about #5 since its the most money. Then, maybe buy the #4?
/ Broken axle shaft! #15
Try to get the jd part number for what you need and check it on ebay. Another option is aftermarket like Glemco or Tired Iron
378909 (A61166)
378909 (A61166)
Pallet of Docking Stations (A60353)
Pallet of Docking...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
TEST YOUR BID BUTTON! (A62131)
TEST YOUR BID...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
LandHonor LHR-BLC9010 Rolling Tool Stool (A60353)
LandHonor...
