Loader John Deere Selective Control Valve
/ John Deere Selective Control Valve #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
Awhile back someone was kind enough (KennyD?) to give me some part numbers from the John Deere sight with instructions as to how to access the parts catalog. As none of my efforts have succeeded after a half hour of trying,
I would appreciate some help once more. I need the schematic parts break down numbers for the JD 750 compact tractor SCV as my loader now goes up all by itself. Any aid will be much appreciated. I'm thinking an internal spring broke but cannot be sure.
/ John Deere Selective Control Valve #2
The web-site you are looking for is JDparts.com. The link to the parts catalog is on the left side.
/ John Deere Selective Control Valve #3
/ John Deere Selective Control Valve #4
There is a link in my signature Arrow that has a quick tutorial I made. If you need more help lemme know...
Gentlemen thank you very much. Ken ; your tutorial showed me what i was doing wrong. When it asked for "model no" I kept typing in "JD 750 tractor" to distinguish it from the 750 crawler or drill. It always stated "no results found". All I had to put in was "750". Jim: mine is the Cessna SCV. They show a control valve (#22) that looks like a spool so I 'm assuming that's what you are talking about. If I snapped a collar on the housing, this is going to prove an expensive fix.
/ John Deere Selective Control Valve #6
Yes parts key #22 includes the spool as it's only available with a complete valve assembly.
Are you meaning to say if the spring at the end of the spool is broken, I have to buy the entire scv assembly housing?
/ John Deere Selective Control Valve #8
No the spring is available but I think a new spring will not stop spool from letting oil leak by in valve housing. I suppose R&R of spring will tell the tale.
/ John Deere Selective Control Valve #9
Maybe replace o-ring on spool.
Obviously something is not retaining the fluid I heard a slight pop and the loader went up all by itself. There is insufficient force to return the spool to its first position without me pushing on the lever to get it back to lower the bucket.
So the story is finished and the loader works fine. Total cost: $4.39. If it were not for the smart parts guy, I would have been out $700. The float spool on the 750 has a non serviceable spring at the end and thus no part is available. My wire snap ring retaining the spring broke allowing the spool not to center and thus the bucket kept going up by itself. The parts guy poured through his computer images and found a similar wire snap ring holding the spool centering spring on the loader of a JD 318 garden tractor. He ordered it, had it the next day, put it on and eureka, the loader works better than ever. If the parts guy had been the lazy type, he would have just said: "sorry, JD no longer supports this valve" and I'd be out the $700. Do not know about other parts for other JD tractors but if you think no part is available, let the parts guy be your friend.
/ John Deere Selective Control Valve #12
arrow,
Good to hear you got the valve fixed. A good parts man is worth alot.
/ John Deere Selective Control Valve #13
I would buy that parts man lunch!
/ John Deere Selective Control Valve #14
IIRC back when I worked behind a JD parts counter there was a book called the Redbook that parts could be looked up giving parts specifications and cross-reference numbers
I bought him more than that. He could buy dinner for two at a fine restaurant and was elated to do so. I had to wrestle him to the ground before he accepted. Nice guy.
/ John Deere Selective Control Valve #16
Sounds as if a new complete spool valve is needed
Can't get just the spool valve Jim. First the scv is no longer made and secondly, the spool valve is matched to the casing and that is why it was costing $700. Cannot get just the spool valve as they are lapped to the casing.
/ John Deere Selective Control Valve #18
arrow
You overlooked the word "complete" in my statement. As far back as I can remember individual spools weren't available as repair parts. All you can do is get a "complete open center valve" from some place such as Surplus Center that will fit the application.
arrow
I see, you are using "spool valve" as the complete selective control valve. I already fixed it Jim. Didn't have to buy a thing except for a few o and wire snap rings
/ John Deere Selective Control Valve #20
I'm glad you got it repaired. Sorry for the confusion but I was just replying to your statement that was directed at me.
New Holland T5 120 Tractor (A64047)
New Holland T5 120...
(6) SALT BLOCK HOLDER (A62131)
(6) SALT BLOCK...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
UNUSED SDLANCH BI-PARTING WROUGHT IRON GATE (A62131)
UNUSED SDLANCH...
2008 Ford F-450 Flatbed Truck, VIN # 1FDXW47R68EA20949 (A61165)
2008 Ford F-450...
INOP/NON-RUNNING 2004 Freightliner M2 106 Medium Duty Day Cab Truck, VIN # 1FUBCXDC24HM93001 (A61165)
INOP/NON-RUNNING...
