Mowing mowing with the bucket on/off
/ mowing with the bucket on/off #1
howie70
Shenandoah Valley, VA
Kubota B2650
Just got my BX2370 with FEL & MMM. I have read a couple posts on here stating that it is best to remove the loader when mowing to make it more stable. I have a few grades that I will be mowing and in my feeble mind I was thinking the added weight of the FEL would help out. I know it can/will be an annoyance when navigating through my trees, but I am more concerned about stability. Can someone explain how removing it makes it more stable?
/ mowing with the bucket on/off #2
Loaders usually make a tractor a little top heavy on hillsides. Your tractor carrying the extra loader weight while mowing also causes premature wear on your tractor front end. Ken Sweet
I was thinking with the lbucket low to the ground it would help, but I guess the loader arms are still at or above the hood. I think I will remove it the first time I mow. Having a bucket is new to me. My old 9N and Massey Harris didn't have it.
/ mowing with the bucket on/off #4
Howie, at what height from the ground would you consider to be the tractor's Center Of Gravity??? I'm gonna guess on the average SCUT it would be pretty near the engine crankshaft height. Would you think that's an accurate statement?? If not, then adjust the height to whatever you believe to be correct. Now look at the loader frame. Is the bulk of it's weight above or below the COG you determined??? If above, then the tractor is more prone to tip with it on. If below, then the tractor is more prone to not tip with it on. Let us know what you decide.
Beyond all that, with modern quick attach loaders, why would you not take it off?? I even take the loader off my M9540 to do any work where the loader isn't needed. Takes about 2 minutes to remove, 3 minutes to install. :)
/ mowing with the bucket on/off #5
Putting the loader on or off is like tying your shoes. The first few times you tied your shoes as a kid it took forever and you figured "what a pain". Didn't take long and you could do it blindfolded in the dark. Practice it some and you'll never give it a second thought again.
/ mowing with the bucket on/off #6
Take it off. I have a BX2230, so close to the same size. Any FEL you have mounted on any tractor will put the weight of the FEL out in front of your tippy front axle. Not only did you add weight to that axle, you transferred almost the same amount of weight from the stable rear wheels to the front wheels. Having it an inch off the ground still transfers the weight. The COG is only one aspect. The COG with respect to a rocking front axle is also important. You can (and should) ballast your tractor to counter this, but it's just a lot easier to remove the FEL. The FEL makes a dandy emergency brake if you are going down a hill and lose traction. But if you didn't have it on, you probably wouldn't have lost traction anyway.
From my personal experience, I drove my BX down on my hillside set to do loader work. That means the FEL on the front, 50 lbs of weight on each rear wheel hub, and a 275lb bar on the 3ph. I had the FEL and weight bar both about 2 inches off the ground. My tires are also loaded, but no spacers. I parked it in a place where I felt it was sort of tippy which turned out to be between 20 and 25 degrees. I got off and pushed on the uphill side rollbar with one hand and fairly easily lifted the rear wheel off the ground. I then drove to the garage and removed the FEL, weight bar, and wheel weights. I drove down and parked in the exact same place. I could NOT lift the wheel off the ground. And that's why I will never again mow with my FEL on.
Sent from my iPad using TractorByNet
Ok guys, thanks for the helpful advice and not calling me a total idiot for even considering it (at least not out loud). As I said earlier, having a loader is new to me. I will definitely remove it when I mow.
/ mowing with the bucket on/off #9
There is a sponsor on here that I purchased a rolling frame for my loader. It is worth every penny, it allows you to roll the loader back up to the tractor to reatatch, or to put it in a corner out of the way when you do not ned it. I thought it to be no big deal, but my wife ordered it from BXPANDED and it is wonderful for my BX1860 loader, and I take mine off to mow as well!
/ mowing with the bucket on/off #10
My loader is always off for finish mowing. It's more manouverable and the front tires don't rip things up.
When I did some bush hogging it was always on and set low enough to hit hidden objects before the tractor and rotary mower ran into them. Most of the time it worked, but I did whack a few things anyway.
/ mowing with the bucket on/off #11
Altho this is titled to be re bucket, I havnt seen reference to that in posts. If you have a quick release bucket, the removal of that significant weight carried well forward of the front axle has a great benefit/effort ratio.
larry
/ mowing with the bucket on/off #12
As noted, loader/bucket on affects the fore-aft CG and makes going downhill with mower on the ground in 4wd mandatory for any steep slope because the rears (where the brakes and 2wd engine braking are) will be unweighted and slide.
However, (in my opinion) the lateral CG (with which one is most concerned with on a sidehill) will not be changed with a low bucket ...the designers placed the fulcrum in the right place...and, the (center of mass of the) bucket can comfortably ride at or below the CG.
/ mowing with the bucket on/off #13
You might be able to lower the CG a tad, but you also move it considerably forward. Because it moved toward the rocking front axle, you made it much more unstable. The only way it gets *MORE* stable is if you can begin to lower the CG below the pivot point on the front axle. I have yet to see a tractor which has construction and geometry where I believe this would happen.
I've physically proven that to myself using my BX, but I bet the model remains consistent regardless of the size of the tractor.
/ mowing with the bucket on/off #14
I live on a slope, but it isn't 'steep'. I leave my loader on all the time because I'm constantly picking up sticks every time I mow.
Try it both ways, and see which works best for your property. There are no two properties alike on this planet.
/ mowing with the bucket on/off #15
What you really need to do is remove the bucket and attach in it's place a gauge wheel at each side. No, just kidding! (Ducking and running)
Seriously, if you do mow with the loader attached, keep the bucket close to the ground so it can be dropped to the ground quickly if needed.
/ mowing with the bucket on/off #16
The weight of an empty bucket will realy make very little difference to anything if greased properly .
/ mowing with the bucket on/off #17
OK, how does grease make *ANY* difference to stability of the tractor?
/ mowing with the bucket on/off #18
The grease lets the grass pass smoothly under a properly greased bucket. If you do not grease the bucket you may hit rocks, dead fall, antlers and other hidden hazards. :duh:
I keep my bucket down, maybe a foot or less off the ground. That low strategy can be helpful when really bush-hogging. When just mowing I do not have a fear of deadfall and rocks.
I do not have counterweights on my tractor so transport driving with the bushhog up in the air makes the front end too light with the whole loader off.
/ mowing with the bucket on/off #19
Now that's funny, I don't care who ya are :laughing:
/ mowing with the bucket on/off #20
I mowed with my L2900 for 14 years with the bucket on to push over saplings and to find large rocks before the mower did. Also, it provided an effective counterweight for the front end when I backed up steep slopes while mowing/brush hogging. I never had a problem with it during this time and when I sold the tractor and loader everything was still tight and functional. Alas, I didn't grease the bucket so there were some scratches and scrapes I could have obviously avoided. The key on steeper slopes is vertical rather than horizontal movement and low speeds. It takes awhile and a lot of patience, but you can safely mow them if you plan ahead and take your time. The bucket particularly helped when mowing nasty plants that attack you such as multiflora rose.
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
2004 Toyota Camry Sedan (A59231)
2004 Toyota Camry...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
