JD 750 scv
/ JD 750 scv #11
Well, it is up to you about float, but you said the spring that does the spool spring centering is what is broke.
You could kill float, but that would not help the spring centering.
/ JD 750 scv #12
The spool is already a lift spool whether you have the float or not.
/ JD 750 scv #13
arrow
Is your safety and possibly anyone that gets around your loader safety worth the price of a new valve??
/ JD 750 scv
The spring is intact. It was a wire retainer clip that was broken that held the float valve onto the spring. This freed up the spring that John Deere stated should not be removed. It removed itself but the spring itself is in good shape. It seems if I move the collar up like it is on the lift valve, supply the spacer and affix the spring at the top with an e-clip, I'm thinking this would work no? It would operate like two lift valves instead of one of them being able to float.
/ JD 750 scv
arrow
I'm not sure I'm understanding this Jim. I expect the loader to operate just like it did only w/o float.
/ JD 750 scv #16
The safety issue I was referring to was loader boom rising on it own accord. If valve functions correctly without "float function" after your repair then I suppose there's no safety issue. In all my years of operating a FEL I like you have found very few times the float was required.
/ JD 750 scv #17
You must never do any leveling or back dragging.
/ JD 750 scv #18
We had similar problems with our 950 well over twenty years ago. After several attempts to repair it by ourselves and Deere, I finally wholesale replaced it with a Northern Tools old school lever valve assembly that I attached to a bracket I welded to the lower boom attachment.
Still works well
/ JD 750 scv #19
No only use loader to pick up objects and load/unload rd bales of hay. I understand about back dragging but I'm not into soil leveling.
/ JD 750 scv #20
I never use float when back dragging I can do a better job with the tractor weight and where I put the bucket.
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2019 GALYEAN...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
