JD 750 scv
/ JD 750 scv #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
Mine has gone awry. Loader goes up by itself and does not remain in first position unless I push lever. JD does not sell the spool assembly and instead one has to buy the entire housing for $700 which includes the spools. Have checked the used market, Cessna/Eaton and even some Yanmar sites to no avail. The SCV is a Cessna 30832-30C. Have pulled the spool out and the alleged "cannot service spring-do not attempt to remove" fell onto the work bench. Any suggestions would be most appreciated.
/ JD 750 scv #2
Find a similar valve if you can't find the same 1. Cessna doesn't sell rebuild parts for what they made. Best bet is to find an equivalent part.
/ JD 750 scv #3
Surplus Center has a valve that will work fine on your tractor.
/ JD 750 scv #5
Can you show a picture of your valve?
What is the purpose of the valve?
You may not be able to get replacement spools, but you probably can get springs, o-rings if it has them, etc.
How many spools.
Do you need float?
Do yo need detent?
It sounds like the spool is not centering, therefore allowing fluid to pass on to the cyl.
Can you make the lever center, and not have the cyl extend?
/ JD 750 scv
How many spools.
Do you need float?
Do yo need detent?
The scv controls the loader JJ. It is two spools. I took apart the spool and there is a small (1/4) wire ring that has broken . This little wire clip is holding up the entire repair and fits like an e-clip would except this clip is round. John Deere states that this is a non serviceable spool so this job went from $2 replace this wire ring to $700 because now they want you to not only buy the spools but these spools must come incased in a new housing as well. This little "clip" or ring retainer, holds the float valve spring mechanism. I do not need float but I do need the loader to not go up by itself as it is doing now. The lever has to be pushed in to make the boom go down as it will no longer center by itself and keep the loader still. It is a Cessna 30832 CAV that is no longer made and alleged to not be rebuild-able with another spool set.
/ JD 750 scv #8
Maybe you can make a new clip from part of a coil spring. Some hardware stores have selections of springs. You can just twist the coil with pliers to make it go straight around the spool instead of helically.
Doesn't sound like a huge problem to me.
/ JD 750 scv
Actually this sounds like a great idea. Whether or not it is a huge problem remains to be seen. My hands are not that finesseful. As a surgeon, I may have gone a week before I got sued.
/ JD 750 scv
This valve would be the best alternative I can think of.
Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
Has float and regen.
I did call this place but they had nothing to help retain the original look of the tractor. JJ, you posed a pertinent question: "do I need float". I've use float about 3 times in 27 years. What is to stop me building the float spool as if its a lift spool? This way i wouldn't have to mess with the float spring and detent ball valve at all. I might have to get the same dust cap and a spacer but as long as the loader centers, I could easily go without float. Whada you think?
/ JD 750 scv #11
Well, it is up to you about float, but you said the spring that does the spool spring centering is what is broke.
You could kill float, but that would not help the spring centering.
/ JD 750 scv #12
The spool is already a lift spool whether you have the float or not.
/ JD 750 scv #13
arrow
Is your safety and possibly anyone that gets around your loader safety worth the price of a new valve??
/ JD 750 scv
The spring is intact. It was a wire retainer clip that was broken that held the float valve onto the spring. This freed up the spring that John Deere stated should not be removed. It removed itself but the spring itself is in good shape. It seems if I move the collar up like it is on the lift valve, supply the spacer and affix the spring at the top with an e-clip, I'm thinking this would work no? It would operate like two lift valves instead of one of them being able to float.
/ JD 750 scv
arrow
I'm not sure I'm understanding this Jim. I expect the loader to operate just like it did only w/o float.
/ JD 750 scv #16
The safety issue I was referring to was loader boom rising on it own accord. If valve functions correctly without "float function" after your repair then I suppose there's no safety issue. In all my years of operating a FEL I like you have found very few times the float was required.
/ JD 750 scv #17
You must never do any leveling or back dragging.
/ JD 750 scv #18
We had similar problems with our 950 well over twenty years ago. After several attempts to repair it by ourselves and Deere, I finally wholesale replaced it with a Northern Tools old school lever valve assembly that I attached to a bracket I welded to the lower boom attachment.
Still works well
/ JD 750 scv #19
No only use loader to pick up objects and load/unload rd bales of hay. I understand about back dragging but I'm not into soil leveling.
/ JD 750 scv #20
I never use float when back dragging I can do a better job with the tractor weight and where I put the bucket.
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
2008 DOOSAN G25 GENERATOR (A60736)
2008 DOOSAN G25...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59908)
2006 CHEVROLET...
Mini flat bottom grapples (A61567)
Mini flat bottom...
2013 MERCEDES-BENZ SPRINTER VAN (INOPERABLE) (A60736)
2013 MERCEDES-BENZ...
