Triton capacity questions
/ Triton capacity questions #1
bigcontender
Member
Binghamton , New York
Gravely 424, 20G
I bought a used Triton Elite trailer and would like to find out the weight capacity of this trailer.
Previous owner bought it from an auction, trailer is registered as a 1992 home made.
Model on frame is Triton Elite, it's aluminum, inside bed size is 6' 4" by 12', with a very sturdy aluminum arched ramp gate.
Axle is a Dexter 1 1/16" axle, axle crank arm measures 6 3/8". The only id on the axle is left crank arm 30-46, right crank arm 89-48.
I haven found any other model , id numbers on the trailer.
Any feedback appreciated.
Thanks
/ Triton capacity questions #2
How many lugs hold the tire on? Generally speaking, 5 lugs = 3500# axle. 6 lugs = 5200# axle. 8 lugs = 7000# axle.
Aaron Z
/ Triton capacity questions #3
Aaron Z
Yep. Only other limiting factor is thr construction and coupler itself. Take the lowest of all these then make sure the tires have the needed capacity.
Chris
Thanks for the replies
Coupler is rated @ 3500#
Wheels are 5 lug.
Tires are rated at 1100 #.
Looks like the tires are the limiting factor.
/ Triton capacity questions #5
Yep. Throw some better tires under it and you are good for 3500# (minus trailer weight) if you have brakes. 2999 or less if you dont.
Aaron Z
/ Triton capacity questions #7
Aaron Z
That depends on the state. Indiana does not require brakes till 3501# Kentucky does not require brakes at all.
It varies state to state.
Chris
/ Triton capacity questions #8
Chris
True, but bigcontender is from NY and NY requires them on trailers over 3000#.
Aaron Z
/ Triton capacity questions #9
Aaron Z
Got ya. Untill he gets more tires he is limited ti 2200# or about 1500# payload.
Chris
I removed the storage box from the front of this trailer to do a repair and found the original Triton data plate.
Trailer is a UT-10 with a 2500# gross weight capacity. Nice to know, thanks for the help.
Now the only problem is I now have the vin number for a trailer that I registered with NY state as a home maid. The previous owner bought this trailer at an auction without a registration so he got a home maid registration from NY. So my delima now is should I tell the NY dept of motor vechicle that this is not a home maid trailer and it has a vin number?
/ Triton capacity questions #12
I would. Just explain what happened and what you found. It will make it worth a few dollars more.
Chris
Rogator RG1300C (A63688)
Rogator RG1300C...
(1) 94"X60"X3/4" STEEL PLATE (A64281)
(1) 94"X60"X3/4"...
Coats 90X-AH-L Tire Changer Machine (A61573)
Coats 90X-AH-L...
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A61573)
2014 GMC Sierra...
Caterpillar 16G Motor Grader Parts and Service Manuals (A63117)
Caterpillar 16G...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
