My 2n is a working tractor. It at times in spite of all the care I take of it throws me a beanball from time to time. Yesterday I was mowing for an hour and it sputtered lost power and died on me. I noticed I could smell coolant prior to that happening.
I dismissed the coolant smell in search of the ignition failure and ruled out fuel supply first. After the time taken to do that I was able to get her started and limp to the garage at idle, she would not idle up without sputtering and dying. Fearing a week or bad battery I trickle charged it overnight. My 2n is 6 volt.
Fuel supply checked out as being normal by the way. Got up this morning and cranked and cranked it farted a few times but would not fire.
Got home tonight thinking the points were fried (I bought them hastily at TSC and replaced them last fall they have maybe 7 hours on them)
Pulled the distributor tonight checked point gap it was okay, filed them a touch and reset gap, then verified timing and advanced it a hair. Cleaned all the parts mating surfaces and reinstalled.
Barely touched the starter button and she fired up right away. After the warm up I went to mowing spent an hour doing that started smelling coolant again and gradually began to hear the engine changing tones dropping rpm and laboring then the sputtering began again.
Kicked the pto off and got back to the house, I let it idle for 5 minutes to cool down and drank a beer. Shut it down and I can see I have a coolant leak at the radiator just above the center pivot engine side that the fan is slinging coolant onto the dizzy.
When I did the new points I put a new cork gasket between the coil, cap, and dizzy.
As the tie says even though it is a fairly minimal leak, can this coolant be finding its way inside my dizzy and causing this?
Obviously I need to pull the radiator and have it repaired, I understand that. I mow rain or shine (have yet to mow in rain as its been dry in Kansas) do these distributors need extra sealant on the cork to keep them dry?
I hope my issue is damp points, the tractor otherwise is strong and will most likely outlast me.
