Strange Noise M9540
/ Strange Noise M9540 #1
SSweet9c1
Member
Branchport NY
Kubota MX5100DT, Kubota M9540HD12
This past spring I purchased a used 2007 M9540 HD12 with just over 2000 hours. with 1353 loader.
After plowing with it the other day, every time I idled it down it made this awful groaning noise, it sounded similar to when you bottom out a hydraulic cylinder and deadhead the pump... I couldn't really tell if it was related to clutch position (hydraulic wet disc). As soon as I throttled it up the noise went away. As the tractor cooled down I could idle it down lower and lower before the noise came back.. IE. shortly after plowing I could only slow the engine to 1500 RPM and after 10 minutes or so I could get closer to 1000 RPM before the noise came back...
I have changed the hydro filters but not fluid. and the engine oil and filter.
The sound is definitely coming from in front of the driver's seat, and it seems like it is coming from near the steering column (top of engine area)
I was thinking it might be either turbo related (due to area of engine) or hydraulic pump related (due to pitch of noise)
Any idea where to start trouble shooting??? It runs great, and everything works as it should...
Thanks
Jonathan
/ Strange Noise M9540 #2
You know, mine has been making a funny noise here lately as well. Not sure if it is the same one you describe though.
I'll be calling my dealer to come take a look. If he isn't too busy it will probably be tomorrow after they close at noon. I'll let you know what I find out.
Not long ago there was a thread or two here about m7040's making funny sounds. I never did read what happened. It might be worth digging them up.
/ Strange Noise M9540 #3
I've also heard some guys talking about a similar noise. Seems it's related to the power steering. When my tractor sits out in cold weather and is cranked it makes a noise similar to what you are describing until the hyd oil warms up. With mine, if I turn the steering wheel slightly the noise goes away for a few seconds. And it makes less noise at idle and only perks up when rpms are increased. Anxious to see what you guys figure out.
/ Strange Noise M9540 #5
What you describe sounds a lot like me at the end of a long day.
PMH
Yeah, I've learned to ignore that one though.
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
Bobcat MT85 (A60462)
2005 John Deere 7420 (A60462)
2005 John Deere...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
