Got a wee bit of a property line issue
   / Got a wee bit of a property line issue #61
If I absolutely knew where the property line was I would just remove the fence, or whatever was on my property. Burn it, sell it for scrap, etc.
   / Got a wee bit of a property line issue #62
Do a little reading on Hatfields/McCoys before you do anything rash (in fact raise that with the neighbor). If they are trying to pull an "adverse possession" stunt, you'll know it. As noted several times above, state laws are all over the map. But since the whole concept comes from English common law, I think it is universal that "possession" be "adverse", meaning use of the property was without your knowledge. From there it comes down to "how long" (state by state) and what constitutes "possession" (again state by state). E.g. in Wisconsin "possession" means permanent structures (driveway/fencing doesn't work).
Since you are bringing in a surveyor anyway, make sure they flag the reference points for you to view. Here the practice for decades has been iron posts that can be hard to find in woods/brush. And I'll add that the penalties for moving one of those markers is pretty harsh (for good reason).
   / Got a wee bit of a property line issue #63
If you need your property to be fenced. Then taking the fence out may be counterproductive.
If someone came and ripped out one of my fences (in good condition) without permission, I would insist that they put a decent quality fence back (at least of similar build to other fences on the person's property that ripped out the fence), with new materials.
   / Got a wee bit of a property line issue #64
But what if your fence was on my property??? That's the issue here. That's the clarification that's needed by Mr Edlegault. In my case, I knew where the property line was and knew the fence was built on my property. I think Mr Edlegault will find the same thing with his issue.
   / Got a wee bit of a property line issue #65
I cannot understand how someone can go to the expense and trouble of building a home without having a survey done to definitively establish property lines...
When it's out in back of the woods with nothing near it, including no commercially harvestable timber or other resources, it's not a major problem if it zigzags around and evens off. That changes when you put a structure up that changes the use category, and your use of the property. I my case, these folks permanently destroyed my ability to hunt on several acres of my own property due to the 300 foot rule in NH. It's to my benefit to ensure I maximize what I have left. Hence, nailing that line down now.
Adverse possession is just one more way of saying possession is 9/10ths of the law.
   / Got a wee bit of a property line issue #66
What about an analogy. Let's say you park your tractor in my barn. I call you and say, "I need you to get your tractor out of my barn, please." And you say, "Sorry. That's where I want to park it. That's where my daddy parked it, and his daddy before him." I realize that it'd be out of line for me to immediately go out to the barn and set fire to your tractor, but how long am I supposed to let you park your tractor in my barn before I just tow the dang thing out of there and leave it on your doorstep? And how many times should I allow you to return it to my barn before I make the dang thing disappear entirely?
We're focused on the destruction of property of the fence here, but let's also remember that the legal owner of the property is being deprived of his use of that property at the same time. How long is the owner supposed to bear that insult? If he or she bears it long enough, adverse possession may kick in, and then you'll have injury on top of insult.
   / Got a wee bit of a property line issue #67
Pretty stupid isn't it? Barring the removal of the structure, the price of the land it is encroaching on can be more expensive than HP Inkjet cartridges (the most expensive commodity on the face of the earth, just ahead of Gillette Trac 3 shaver cartridges). In this day with GPS etc., a proper survey doesn't cost that much.
   / Got a wee bit of a property line issue #68
To the OP, and I hate to say this, I am a land surveyor and I agree with so many others, make the guy move his fence over to the boudary line. I have done to many jobs where there are hard feelings between land owners and it can spiral out of control. I would have your surveyor talk to the guy and let he know this is the "offical line" and his fence is over it. If he doesn't move, move it for him.
I will tell a short story. I did a survey about 20 years ago. The adjoiner called and said our survey was wrong. We checked our work and it was correct and it turned out the guy had lost his ground because he wasn't able to keep up with the payments. In other words, sour grapes. Fast forward about 3 years ago people bought the adjoining land and we surveyed the land again and there was a fence on the new line and it was in the wrong place. I also found the markers from my previous survey, and at first I thought they were in the wrong place and I had made a mistake 20 years ago. After checking several things, I determined the guy had moved my markers 20 years ago when he complained and after I had left the job site and had then built the fence. When I confronted him, he blamed it on the guy that had built the fence for him. I talked to the new land owners about adverse possesion, getting a lawyer, and that I was 99% sure his adjoiner had moved the pins 20 years ago but I couldn't prove it. This new land owner did what I consider a pretty gutsy thing, he talked to the adjoiner about moving the fence but he wouldn't do it. He then went out with a bull dozer, took the old fence out, and built a new one on the correct line. He related to me he told the guy he would see him in court if need be. I always admired him for doing this, but he also knew I would go to court for him and swear the corner markers had been moved.
I can't recomend this kind of drastic action, but like I said, I admired the guy for doing it, and it turned out to the correct course of action for him to reclaim the land.
   / Got a wee bit of a property line issue #69
Just looked at Wisconsin law...seems the fine for moving a marker is only $250 (needs to be inflation adjusted I think) but it also says up to a year in the county pen.
   / Got a wee bit of a property line issue #70
That was my point with my neighbor. In my case, he gave in and moved it. It would not have bothered me to tear out his brand new 6 barbed wire fence. He knew that. He also knew that in the end he would have to bear the expense of building another fence in the proper place. I have no livestock and no need for the fence so it didn't matter to me. I was calm, rational and mature in my conversations with Kevin. But he also knew I was the craziest guy in the "bar fight" and wouldn't hesitate to take action. As my Grandpa would say "To deal with the bastards you gotta be a *******".
Mac 3200 Chainsaw (A57454)
Mac 3200 Chainsaw...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
*Selling at Royal Auction Zephyrhills, FL Location* 7 (A59228)
*Selling at Royal...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
Toro Reelmaster 6500 D (A57453)
Toro Reelmaster...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
