Brain dump !
/ Brain dump ! #1
Uncle Levi
Maxbass, north Dakota
John Deere 2020
I have an old Oliver ground drive spreader that someone gave me. It worked perfectly until one of the tires blew out the sidewall. While I'm waiting to get new tires I'm going to restore it to origional condition. I think it's a model 17 ( the ID plate reads: Oliver Superior manure spreader Serial number 17-1355). But here's the brain dump part. I took off the front board because it was bad and I'm going to build a new one. But I can't remember which way the "notch plate" goes. The one the levers notch in to. Two notches on the left ,multi-notches on the right or the other way? Also is it possible to get a manual for this spreader? You guys are always a great help and I'm someone can help here. Thanks much.
/ Brain dump ! #2
You are correct. Two notches on the left (toward serial plate) the multi notches on the right.
/ Brain dump !
Thank you Mike! That saves me a lot of grief. I'll post a picture of this thing when it's finished.
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
2014 Kubota RTV X900 4x4 Diesel Utility Cart (A61567)
2014 Kubota RTV...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2014 Bobcat T550 Compact Track Loader Skid Steer (A61567)
2014 Bobcat T550...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
