Ratchet Rake - ever seen/used one?
/ Ratchet Rake - ever seen/used one? #301
There have been LOTS of posts regarding the Ratchet Rake over the last year or two and yours is the first one I recall where the rake has sustained any kind of damage. Glad you were able to fix it easily.
I didn't think I would be using my RR in the winter but with frozen ground, then lots of rain that can't soak in, then more freezing temps, I might try using it as an icebreaker on my driveway.
/ Ratchet Rake - ever seen/used one? #302
My thoughts exactly. I've got the 54" model on my BX. The whole thing is 1/2" thick metal. How the heck did you bend one with a small tractor?
My back yard has been coated with ice and it isn't flowing enough to run down the hill; jammed up by snow. I thought about scraping the ice off with the rake also. The bucket just slid on top. The rake might move some ice, but would create some channels for the water to also flow better and get out of there. The dogs came in last week soaked. Have to be careful to not dip into the lawn though.
/ Ratchet Rake - ever seen/used one? #303
The part that bent was the far right tooth. It is probably the most vulnerable part of the entire thing. I try to make it a point not to use the bucket on the sides to pry, but I probably didn't see something in that hole.
Let us know how it does for breaking ice, I am curious how well it will break it up. II wonder if making a channel would do the trick. I found that pointing the rake down and turning while going back and forth has a sawing acting to make little trenches.
/ Ratchet Rake - ever seen/used one? #304
I finally went out and tried this this afternoon. My wife loves to fill her bird feeders and having her slip and fall would not be a good thing. I don't think it is useful to removed a lot of ice, at least not on grass. It does dig in and rough it up a lot though so it should help with the slippery factor. I think it might have some use on a gravel driveway, but even on my grass, it tends to catch a tooth now and then in the sod and that can bring my bx to a halt. The whole surface is now like crusty snow instead of glare ice, so I see a benefit from it. I thought the large teeth would be easier to follow, and that's true. I dumped the bucket to about 80 degrees. But the smaller teeth do a better job because they are closer together and break it up more. I tried it with the bucket curled back to about -10 degrees. Another option would be a dump of about 60 degrees see the small teeth dig in, but I didn't try that.
/ Ratchet Rake - ever seen/used one? #305
Thinking of getting one for a 72" bucket...
Anyone use the FS model with load binders?
/ Ratchet Rake - ever seen/used one? #306
Just called to place my order for a standard ratchet rake and learned they are out of stock estimating 4 to 5 weeks.
/ Ratchet Rake - ever seen/used one? #307
I just ordered one through the TBN store today. Hopefully it's not 4-5 weeks...
/ Ratchet Rake - ever seen/used one? #308
The only one available is the 72" FS model with chain binders if my information is correct.
In 4 to 5 weeks the ground will be much harder for what I want to do.
/ Ratchet Rake - ever seen/used one? #309
Have you checked with your local TSC ??
Love mine to clean my roadside ditches with mine.
/ Ratchet Rake - ever seen/used one? #310
TSC is out of stock here. All 3 stores within 75 miles.
/ Ratchet Rake - ever seen/used one? #311
I called the 3 closest and they are not really that close...
No luck, special order, prepayment required.
/ Ratchet Rake - ever seen/used one? #312
I just ordered one this past week, received an email shortly afterward saying that it shipped out and is on its way.
/ Ratchet Rake - ever seen/used one? #313
I tried to order one on Friday and I was out of luck...
/ Ratchet Rake - ever seen/used one? #314
You can order via web, directly from ratchet rake and have it delivered to you. Shipping was only 29 bucks, not bad. You never have to leave the couch!
/ Ratchet Rake - ever seen/used one? #315
But they are currently out of stock...
/ Ratchet Rake - ever seen/used one? #316
I just got word that I got my order in just in time, and mine will be shipped tomorrow. Can't wait!
/ Ratchet Rake - ever seen/used one? #317
Just got mine today, now that's some package. I had it shipped to my office , I thought the FedEx man was going to die after the two flights of stairs! You should have seen his face, he had no idea what he was delivering.
/ Ratchet Rake - ever seen/used one? #318
WooHoo those tulips are in big trouble now! :thumbsup:
/ Ratchet Rake - ever seen/used one? #319
I just want you to know that was supposed to be mine!
Called today to order the chain model and had to leave a message... can't wait 5 to 6 weeks for the strap model...
/ Ratchet Rake - ever seen/used one? #320
Mine is to be delivered on Thursday. Tractor will hopefully be here by then...
I found one at a TSC about 120 miles from me (calling around while waiting to hear if my order was placed in time). If you are interested, I can give you the number and you could see if they would ship it to you. I think they have a 52" and 68" in stock.
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
Fimco 260gal Sprayer (A61166)
Fimco 260gal...
2012 NISSAN ALTIMA SEDAN (A59909)
2012 NISSAN ALTIMA...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A61569)
2014 Crossroads RV...
