oat hay Baling issues
   / oat hay Baling issues
And of the stuff I bale. Yesterday one was at 22% that was a bale in the shade for a lot of the average bales when I pick them the strings pull about 8 inched off the bale
   / oat hay Baling issues #12
12-15% moisture is where I want to bale the hay. I still think 7% hay should fine to sq bale. Are bales coming out of chamber even or banana shaped? In my youth my Dad baled 1000's of bales of oat hay with a 214WS
   / oat hay Baling issues #13
Hmmm, ~20% is where we stop and let it dry longer. Like Tx Jim, we shoot for 12-15% moisture. Sounds almost like your bales aren't being held back well enough by the bale chamber, but if they are 80-90# bales, that is too heavy...
Aaron Z
Yah the higher moisture ones get to get fed first. All the old timers here say just let them sweat for 6 months. Bales come out perfect looking. When you cut the strings and compare length it hasn't been more than a quarter inch difference.
   / oat hay Baling issues #15
I can't see how string will pull 8"s from bale when picked up if bales weigh anywhere close to 80#s. How long are the bales?
They are 3 feet. I'm going to weigh a few and try some pictures to clear it up.. on another note. This Baled has the compressor rods on the pick-up that just go straight back I see in the manual they have some that come forward then curve down and back up towards the back like an s shape. If I get/make some like that will that help pick up the hay? It seems that it likes to throw a lot of the hay forward unless its roped on the windrow. Also thanks for all the time spent with me. This is my 3rd season haying @ 30 acres. Last year was better had none of these problems but had better rain.
   / oat hay Baling issues #17
Yes the curved compressor rods help hold the hay against the pickup teeth and strippers better than the straight comp rods. I can't remember seeing a 214 with straight comp rods. Photo's would help. This 224 that I found on the internet has flat compressors.
   / oat hay Baling issues #18
Let 'em "sweat" for 6 months or so... You'll have mold that won't quit! If you've got 80's now and 90's in several weeks... mold in 2 weeks - darn near guaranteed - with 22%> bales.
AKfish
   / oat hay Baling issues #19
I can't believed they haven't dried out if cut a week and half ago. That is a long time
Sent from my iPhone using TractorByNet
Ak yah I feed the higher moisture bale as soon as I bring them home. As far as getting any more rain it is probably over till October. Gotta love this desert ish weather here in Ramona.
1541 (A57192)
1541 (A57192)
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
ALLISON TRANSMISSION (A55745)
ALLISON...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
