Price Check First fluid change and workup
/ First fluid change and workup #1
Brutus51
New Lexington,Ohio
BX25
I have a BX 2360 with about 70 hours on it and I know it's past due for its first work up. What's a good price to have all the fluids changed and it looked over?
/ First fluid change and workup #2
Save your money and do it yourself,its not that hard and there are plenty of members on here that can walk you through it and by doing it yourself you will feel better about it and also learn a little more about your tractor.:cool2:
I am completely fine with doing it by myself but I was worried about voiding the warranty. Is that an issue or as long as I document what I do and what I use does that make it ok!!
/ First fluid change and workup #4
/ First fluid change and workup #5
Read the threads posted by TripleR and do your own. It will help you understand your tractor a bit better and you will probably do a better job than the dealer since it's your machine and you'll pay more attention to what your doing. Dealers don't usually assign standard filters and fluid changes service to their highest paid mechanic.
/ First fluid change and workup #6
do your own service an save that $200 labor charge.
/ First fluid change and workup #7
Great thread! Bookmarked and tagged the links. Thanks!
/ First fluid change and workup #8
just check the ft axle/diff levels a few times after a few hrs of use after change...takes time for fluid to settle. may have to top off.... maybe even the hyd levels as well.
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61567)
2017 Bad Boy...
Kubota ZG222 (A60462)
2018 Unverferth 3955XL Seed Tender (A63116)
2018 Unverferth...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A62129)
2014 CATERPILLAR...
