My Harbor Freight Trailer for TransMule
/ My Harbor Freight Trailer for TransMule #1
hunterridgefarm
Western NC
Kubota L3130DT, Kubota L185DT, JD LX277
I have been looking for a good size trailer to pull behind the mule. I need it to haul tools, fertilize, and produce out of the field. I take people down to the field in the mule and constantly having to move stuff out of the bed in order to convert the mule for 4 people. I needed one that was not to wide since I need to make a 180+ degree turn on the way down to the field.
I look at several sizes and many used small trailers. A Harbor Freight recently opened close to me so I decided to check them out. This is the first item I have purchase from them.
It is 4' x 8' with 1700# of capacity and cost, after discount coupon, $275.00. The bed also tilts. It took about 2-3 hours to put together, pack the hubs with grease and another couple of hours to attache the decking and side rails which was not included in the cost. It would take less time if you pay attention for the directions:eek:.
I purchased deck boards from Lowe's for the bed and rails. I will cut the side rails off once I decide if it is high enough.
I need to get a 2" adapter this week for the mule so I can raise the trailer hitch to be close to level.
I think it will fit my needs well and a good price. It also came with a light kit but I chose not to put them on.
/ My Harbor Freight Trailer for TransMule #2
$275 is a fantastic price! Curious if anything like that is in Canada, ie Princess Auto?
Does it have torsion/rubber suspension or leaf spring?
Can it be licensed for the highway?
It has leaf springs, comes with a title and can be tagged for the highway.
/ My Harbor Freight Trailer for TransMule #4
I have a similar HF trailer, with about 1000# capacity that folds and stands on casters in the garage. This enabled me to get rid of a pickup and still have the capacity to pick up large items. I love the fact that it folds easily and only takes up a floor space of about 5'x2' when standing. Keeping it out of the weather, it still looks like new and doesn't look like a lawn ornament.
The best deal is to wait for a sale then use the 20% coupon.
/ My Harbor Freight Trailer for TransMule #6
Have you protected the wood? Some linseed oil might be in order.
I considered buying that one but it was a little too big for me. I went with one of those 4 x 5 ft. steel mesh trailers that Lowes sells in front of their stores. It is very well built and heavy duty for around $400.
Good looking trailer, I bet you have already thought of one change that I would do. Hint, the hitch looks low.:cool:
I have a 6" drop hitch I flipped and installed yesterday. I had to go to TSC and get a 2" adapter for the receiver on the mule.
The wood is treated decking so it should be good for several years.
/ My Harbor Freight Trailer for TransMule #9
Nice looking set up, and for an excellent price!!!
Eddie
/ My Harbor Freight Trailer for TransMule #10
Looks great!
I have often thought about doing something similar to tow behind the BX.
/ My Harbor Freight Trailer for TransMule #13
Hi,
I just saw this thread, and I also bought one of the smaller HF trailers, and I put AG tires on the trailer because I will be using it in the woods, and I wanted better traction when I am going across small grades,. Not really necessary, but I had the tires sitting around. This is my smaller trailer with the sides kit from HF that I just built. I also coated the floor with Rust-oleam Restore. Great little trailer:
/ My Harbor Freight Trailer for TransMule #14
I have a Haulin brand flatbed trailer, originally from Home Depot from the mid 90's. I've got a lot of good use of it on the road. It is a little more substantial than the HF trailers, but still very lightweight for pulling. I had to replace the tongue, and accidentally cut it a bit long and welded both ends before realizing my error. But, I like it long. It means that on an 8 foot trailer, I can carry stuff that is substantially longer than 8 foot long.
The one thing I'd add would be better tie downs.
I would encourage installing the light kit. You never know when the trailer might come in handy for a run to town.
As far as the AG tread, it looks cute behind the tractor, but I doubt it will make a substantial difference for "traction" as you are neither driving, braking, nor steering from that axle. Slipping sideways? In that case, using a front ribbed tire might be an improvement. You can get small, wide tires which might be good, but it would also mean your trailer would stick out a few more inches on the sides. Nonetheless, the AG tires match your tractor nicely.
/ My Harbor Freight Trailer for TransMule #15
Thanks! I remember the trailers that home depot sold, and I haven't seen them for a few years, but that may just be in my area? I had the AG tires from a tiller that we ended up giving back to my grandmother, and had decent tires on it. I know they may not help much at all, but they should be a bit better than what I had, and I do like how they look with the tractor. If it was a ground driven implement, it would be great.. I think that I may add the light like you said. They are just sitting in a box. I do drive quite a bit on the road in front of our farm, but usually the tractor light are enough. I am not sure how the AG tires would tow on the road at speeds around 35mph? It really is pretty small to tow and use since I have the truck bed, and I di have a horse trailer if I really need to tow something large. We buy about 8 tons of hay a year, and tow it about 30 miles to our house from various fields, but I have been renting a 12foot u-haul for that. We were going to buy a larger flat bed trailer, or a used hay trailer, but for $30 a pop renting the U-haul, and having them maintain it, it really works aout well. We usually spend about $130 a year renting the trailer, and that is about 9 years worth of renting to pay for a used trailer.
Is the trailer that you bought from Home Depot about the same quality as the ones that they sell at Tractor Supply?
/ My Harbor Freight Trailer for TransMule #16
I think the new HD trailers look somewhat like the Tractor Supply trailers.
Mine has plywood decking. Mostly welded construction. Single bar tongue that used to tilt, but I never used it that way. I almost lost the tongue once, so now it is welded 3/4 the way back along the frame.
It has 4 stake pockets, but no railing. Mine has 8" tires, which allows it to be low, but 100% flat across the deck to the fenders.
Here is a photo that I posted on here a while ago. I keep planning on adding tie-downs, but haven't gotten around to it yet.
Anyway, I suppose a trailer is only as good as what you need it for. Sometime I'd like to make a small tandem axle trailer from scratch, but haven't gotten around to that yet.
You can get reasonably good tandem axle farm trailers for less than $1000, but like you said, that also includes maintenance, and perhaps new tires which add up quickly.
Mom still has the hay trailer that Dad built. Sized for carrying about 70 bales of hay. Fenders flush with the edge of the trailer (less to get knocked by when loading), and the fenders the height of 1 bale and length of 2 bales.
/ My Harbor Freight Trailer for TransMule #17
I bought one of the Harbor Freight trailers. Used it for awhile behind my four wheeler. Sold the four wheeler and got a Kubota 400. Mounted both my sprayers in the trailer. Installed a folding jack wheel and keep it under a shed. The sprayers were pretty heavy full trying to get them into the bed of the UTV. Now the bed is still available and I just back-up and hook-up. The trailer has been as handy as a pocket on a shirt.
